2 Pages<12
nikosman88
#21 Posted : Monday, June 16, 2025 2:28:25 AM(UTC)
nikosman88
Greece
Originally Posted by: suzun Go to Quoted Post
Thank you very much for your answer.
I definitely take your advice very seriously.
As Bus C, I set the LG TV connected directly to my laptop with hdmi.
(webOS TV (NVIDIA High Definition Audio)
Also the default bus setting is Master.
All Guests receive the audio from the call as master.
I did not need to separate the guests into Bus A and Bus B.
They should all reach every audio and video going to the broadcast.
Output 1 goes to the guests and I use this TV as FullScreen to watch the broadcast live.
When I had only one guest on the broadcast, there was no echo even with the automatic gain microphone setting, but when the second guest joined, I had an echo problem.
If I think I absolutely cannot do it, I will switch directly to the headphones.
But as you can see,
If I have a chance, I want to try and learn.
Thank you again for your understanding.
Hi. You are not the first person that mention this thing.
https://forums.vmix.com/...-still-callers-have-echo
https://forums.vmix.com/...l-Participant-Hears-Echo
https://forums.vmix.com/...king-with-Rodecaster-Pro
Saying that professionals use headphones and un-professional no,my personal opinion is that cannot help to find the solution. As you said other broadcasters have no problems with this. In the posts i send you,there exist solutions and an obvious thing. The mix minus/echo cancelation in vmixcall is not so "professional" compared to zoom or other programs like skype that i personally miss allready. Ok maybe the most High Audio quallity is true,but in real world scenario for un-professional (not high budget streamers because everything is how much costs when it comes to equiment) zoom/skype way,work better
I work in a small tv station in Greece. What you describe is same like my scenario. In the studio i send the audio return via a tv hdmi audio from Vmix Fullsreen out.
My talents dont wear any headphone. Sometimes for example before 1,5years we had elections and in the studio we had 5-6 people with 1 mic per person. So in theory 5 mic to make "echo". In practice our show presenter can wear a headphone when we have a videocall or phonecall. But what for the other guests? They will not hear the videocall/phonecall or we are obliged to have 5-6 wireless headphones per day (in order for changing for health reasons the headphones cover or say guests to bring their headphones) ?
Measures that worked for me
1.Inside the studio i send BUS G that is gpu-->hdmi out-->tv in the studio. In this BUS i send the audio from callers or phone call
2. In any of the mics i select BUS F and i send it to videocall/phonecall. Skype was running in a separate pc in which via ndi tools-->webcam i send video/audio from main vmix pc and back to main vmix pc from skype i take ndi feed per person
3. The speakers in the studio should not be too close in the people table and not too loud. Set them in a level that anyone can hear and not too loud.
4.In any mic and skype feed/phone call audio i put this https://www.wtautomixer.com/ vst3 plugin. Yes it costs 160$ but it work. It has 7 days trial so you can test it, if also work for vmixcalls. Anyway this plugin in our studio without any serious soundproofing,with echo and it does a great job.
5.Skype close was for us in the end of our season shows. So for now i hadnt yet the oppurtunity to do with same setup in real show conditions 2-3 vmixcalls same time to see what happens. I hope that i will not have problems at mid of september we start again new shows. Because as un-professional to have headphones per guest is not in our budget. About mid september i will be able to test it.
2 Pages<12
