GameWithSasha
#1 Posted : Wednesday, March 27, 2024 8:03:39 AM(UTC)
GameWithSasha
Ukraine
I encountered a problem when adding 3 SDI cameras through the Decklink Duo 2 to Vmix. Strangely, when each camera is added, the CPU starts to heavily stutter. After the first camera, it's at 5%, after the second, it's at 50%, and after the third, it jumps to 100%. Interestingly, when performing similar actions in OBS, the CPU load is only at 3%, and all cameras work simultaneously without issues. The problem is likely in the settings, and high-performance mode is enabled in Vmix. All drivers are up to date, and connections are correct.
kross
#2 Posted : Wednesday, March 27, 2024 10:29:02 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
You're going to need to provide a lot more detail than that.
What is your hardware? CPU, motherboard, etc.
What video format? What are all the settings on the input properties when you add the camera to vmix? (resolution, frame rate, interlaced, video format)
GameWithSasha
#3 Posted : Monday, May 27, 2024 11:01:42 PM(UTC)
GameWithSasha
Ukraine
Windows 10 Pro 64-bit
Intel Core i7 8700K 3.7Ghz
GTX 1080TI 11gb
HDD ST4000DM004-2U9104 4TB SSD TS1TMTE110S 1TB SSD TS256GMTE110S 245GB
32(8GB*4)GB DDR4 2133GHz
Asus ROG MAXIMUS XI HERO
Intel Cannon Point z390, Intel Coffee Lake-S
Format: 1920/1080 30p SDI
Kayo33
#4 Posted : Sunday, June 15, 2025 6:07:25 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
GTX 1080TI 11gb
1 - GPU on pcie x16_1 slot and BMD Duo 2 to PCIe x16_2 slot
2 - Windows 10 Pro and Vmix on M2_1 SSD slot
3 - Vmix settings
4 - update firmware Duo 2
Otherwise, reinstall Windows 10
Capture d'ecran 2025-06-14 210044.png (127kb) downloaded 42 time(s).
