[Issue] vMix Buffer Overflow / Yellow Stream Button / Frame Drop — Since v27
System Overview:
vMix version: 28.0.x (problem started after updating from v26) Resolution: 4K 30fps (constant) Hardware: 3x Blackmagic Studio Camera 4K (via SDI) ATEM Television Studio 4K SDI to HDMI converter → DeckLink 4K (PCIe) CPU/GPU usage < 10% in vMix Workflow: vMix for switching, output to OBS via vMix External + VB Audio Cable, OBS as encoder (only stable method so far) Internet: High-speed (700 Mbps), stable (problem persists even in ideal network conditions) Symptoms:
Yellow stream button after ~30 to 90 minutes YouTube stream freezes (buffering wheel) Logs show: real-time buffer [vMix Video YV12] too full … frame dropped! or av_interleaved_write_frame(): Error number -10053 occurred (rare, at home) CPU, GPU and Render Time are consistently low Happens even without live input, e.g., playing a 4K MP4 for 2 hours produces same result Reproducible across multiple locations and networks Tested:
Network seems not to be the only cause: Same issue occurred to a colleague in a different company, using different setup but same vMix version (27+) Streams in Full HD also fail with yellow button (even with low bitrate) Streaming from OBS directly — works fine (even in same network/machine) Streaming over Wi-Fi works; wired connection fails (same internet access, different adapter) Hypotheses:
Regression in vMix 27 or 28 RTMP encoder/buffer handling Interaction with: DeckLink drivers (via DirectShow?) Video buffer overflow due to internal mux/demux issues Potential issue with GPU drivers or codecs (some Reddit users resolved by updating NVIDIA drivers) Possible stack/network incompatibility with Windows 10 — but not confirmed Tried:
Adjusting bitrate, resolution, audio formats Different cables, converters, capture cards Contacted vMix support → Response: "machine, hardware or internet issue" Next Steps:
Planning to test with vMix 26 again on the same machine Full GPU and OS driver update (possible move to Windows 11) Monitoring via Wireshark and external tools
Has anyone else experienced this buffer overflow / dropped frame / yellow stream button behavior after upgrading from vMix 26 to 27 or 28?
Any insights on RTMP engine regressions, driver issues, or encoder tuning would be greatly appreciated.
Thank you,
Gabriel
Joined: 4/23/2017(UTC) Posts: 1,487  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Just a thought. Could it be that in the wired network there is some security scanning that can't deal with streams (they have no end which the scan waits for and fills the buffer until overflow). And that this is not happening on wifi cause it's setup is different. Also if it's always after xx minutes, reproducible, then I would engage s/o from the network team.
