Joined: 6/24/2020(UTC) Posts: 14  Location: BROOKLYN Thanks: 6 times
I have not been able to successfully output and receive a stereo signal using the vMix Zoom API. I am sending two mono channels of audio that needs to be isolated. It is to send music and general session audio to overflow rooms with vmix machines on the sending and receiving sides. The receiving end comes in as combined audio on both channels. Same setup using vmix call works without issue. Anyone have any insight? Thanks!
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
The only option in vMix is "Original Sound for Musicians".
If that's not doing it, then you need the feature request section.
