GT
UTC: Passing Multiple Data Values from List Widget to Title Fields
Today's challenge I can't find an answer for:
I have a list widget Selected Row that uses a Google Sheet as its data source. (NOT a loaded/appended .txt list) It pulls in 4 text values per row from the sheet, separating them by "|"
After I want to take the values of the selected row and pass them to the title: column 1 value > Title Field 1; Column 2 value > Title Field 2 value, etc. Then I can OverlayInputX the title populated with the values selected in the list.
I think it's a SetText but not sure how to parse the 4 separate values in the list widget
Thank you!
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Thank you! There is a video for mapping the list widget in this post: https://forums.vmix.com/...-advanced-tips#post34858The UI kind of changed in the meantime, but the procedure should be the same.
Yes I see how it works with a .txt source file to populate the list, but I'm trying to do it with a Google Sheet if possible to save steps. That way producer can enter names in GSheet and (if it works) the drop-down list would populate from those.
Originally Posted by: jaxon  Yes I see how it works with a .txt source file to populate the list, but I'm trying to do it with a Google Sheet if possible to save steps. That way producer can enter names in GSheet and (if it works) the drop-down list would populate from those. Yes, but from what you wrote you already have the data source running in the list widget, right? Then the title mapping to a vMix title is exaclty the same as in the video. I don't know what else is missing. Maybe post a screenshot from the current state of your widget.
GT
