knbPixels
#1 Posted : Wednesday, June 4, 2025 1:14:15 AM(UTC)
knbPixels
When using the MultiCorder the only options to record are the 4 external outputs, and our 4 inputs coming in through SDI. Checking the box for "Show Unsupported Inputs" didn't add anything else to the list. Is it possible to add Zoom inputs to the MultiCorder list? Why is it that only SDI inputs are shown?
We are trying to record 4-6 inputs, only one of which is coming through sDI, the rest are through Zoom. We are already using output 3 and 4 for other functionality, so only outputs 1 and 2 are available to us, giving us a max of 3 recording channels total. If Zoom inputs were available it would be 10x more simple to select those inptus and not have to use external outputs.
nikosman88
#2 Posted : Wednesday, June 4, 2025 1:26:33 AM(UTC)
nikosman88
Greece
Hi. I believe this need to be posted as Feature Request
knbPixels
#3 Posted : Wednesday, June 4, 2025 1:30:29 AM(UTC)
knbPixels
Since it was a question about how it works and if Zoom inputs can be added to the list of Multicorder inputs, I disagree. Depending on the answer, a feature request may follow. But thanks for trying to make sure I'm posting the right way lol
WaltG12
#4 Posted : Thursday, June 5, 2025 7:07:33 AM(UTC)
WaltG12
Originally Posted by: knbPixels Go to Quoted Post
MultiCorder - What determines which inputs are available?
The programmers.
Some input types, like vMix Call (which, honestly might be the only one) are unsupported in the sense that "you can do it, but if it breaks, we warned you").
Others, like most of them, are unsupported in the sense that it flat out will not work and is not an option.
That box is for the former.
That would be the latter. In other words, no.
Supported inputs on the Multicorder are cameras and NDI.
Unsupported inputs (in the sense that you can try it and it's on you if it breaks) are, again, vMix Calls.
Unsupported inputs (in the sense that it's not even an option) are everything else.
Correct.
There are existing feature requests for more outputs (the option will be added when Martin, etc. feel graphics cards are stable enough to handle it) and for more input types to be available in the MultiCorder (not happening).
I'd recommend doing what I do.
4K = 4x 1080p.
3 4K recording channels will give you 12 1080p videos.
Since most cameras, and Zoom, cap out at 1080p anyway (if they even hit that), you don't lose much.
It's been asked for before, and, again, the answer was "not happening". If you want to rehash it, you can, but I wouldn't get my hopes up if I were you.
knbPixels
#5 Posted : Thursday, June 5, 2025 7:09:56 AM(UTC)
knbPixels
The programmers.
Correct.
4K = 4x 1080p.
Thanks for the info, very helpful!
