Joined: 10/13/2020(UTC) Posts: 25  Location: Annandale Thanks: 2 times
I want to be able to zoom in and out of an active input I think I'm supposed to use this setzoom function but I need to be able to do it in increments of .1 or .5 via my rotary dial
Rank:: Advanced Member
With rotary knobs you have to set the function to zero again, but it depends a bit on what the button returns as value. Usually +1 in the one and -1 in the other direction. To stop the zoom you need to set the stop as well otherwise the zoom will simply continue.
I use a Monogram Orbiter for my PTZ controll. You can set the shortcut to a specific input, the preview, or a dynamic value if you have multiple PTZ cameras. In vMix you can set the Zoom speed seperately. The first task is to get the zoom in, Stop, zoom out. Thne you can use other shortcuts for the speed.
