HDMI fullscreen output looks unsharp (and how I solved it)
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
Hi All, I just want to put out what I have experienced last week. In our setup we use VMix on a laptop. to make it portable. But this time I needed 2 HDMI outputs. Number 1 the internal HDMI to a magewell adapter that is the backup stream via HDMI, if NDI would give issues. Number 2 is via a USB multiport card that was connected to a large Led videowall (4.5 meter by 2.7 meter) number 1 was fine also the internal screen was fine. But the Videowall was... like I was not wearing my reading glasses. If I would connect any other system it was showing correctly. and yes the output was 1920px by 1080px just like the other systems. after 4 hours I found 1 thing that was different for that output. I found out that the windows scale option for that output (extended screen) was set to 125% After changing it to 100% it was showing sharp. I hope it helps someone else.  scale.png (79kb) downloaded 32 time(s).
Joined: 10/10/2019(UTC) Posts: 65   Location: Düsseldorf Thanks: 5 times Was thanked: 17 time(s) in 10 post(s)
