Feature Requests
Overlay Out Title Animation when on a Layer
Joined: 2/7/2024(UTC) Posts: 197  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Currently, if you have an animated title and select it as an overlay number and turn the overlay on, it animated in. Then if you hit the overlay number again or trigger it with Overlay Out, it animates out as it should.
If you put that same title on a layer of an input (Called "Container" for this example), and turn the overlay on, the title on that layer will animate.
However if you turn the overlay off on Container, or trigger to Overlay Out for that Container input, it will not animate out, it fades.
I would like the functionality of all animations for titles to work when they are used on a layer that is put into the overlays.
Joined: 6/10/2025(UTC) Posts: 3  Location: Buenos Aires Was thanked: 1 time(s) in 1 post(s)
Feature Requests
