vMix RSS Feed XAML Animation and Reader!
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Joined: 8/30/2014(UTC) Posts: 3 Location: United Kingdom
Can you provide some instructions on installing and running this please. I added the XAML file as an input in vMix but when I run the .exe file this just crashes on startup. Does it need to be in a particular directory?
rdally wrote:Can you provide some instructions on installing and running this please. I added the XAML file as an input in vMix but when I run the .exe file this just crashes on startup. Does it need to be in a particular directory? It really shouldn't be. What kind of error are you seeing? Add me on Skype (havard_njastad) for even faster support! :) Best Regards, Håvard Njåstad Njastad.com
I run the .exe file - nothing shows for a few seconds and then I get a Windows message box saying "vMix RSS Reader has stopped working" and shortly afterwards a "Do you want to send more information about the problem" box.
rdally wrote:I run the .exe file - nothing shows for a few seconds and then I get a Windows message box saying "vMix RSS Reader has stopped working" and shortly afterwards a "Do you want to send more information about the problem" box. Allright, we've got it sorted! It was a missing .dll file in the .zip folder which we forgot to put in when we made an update to the product. You should now be able to open it normally if you have .NET framework 4+ installed, and the new .zip should be available from your Downloads Page! We're sorry for any inconvenience this problem should have made. Thanks for your feedback! Best Regards, Håvard Njåstad Njastad.com
Thanks for the quick response - it is working fine now. I'll make any further support requests directly but one immediate question - is there a way to show more than just one story item at a time. I was expecting this to work by 'highlighting' multiple lines in the Story List but that doesn't work. Perhaps you could add an option to show the 5 latest stories?
rdally wrote:Thanks for the quick response - it is working fine now. I'll make any further support requests directly but one immediate question - is there a way to show more than just one story item at a time? For example, by 'highlighting' multiple lines in the Story List or choosing to show the 5 latest stories. We'll put that on the Feature Request list and keep you updated via mail or here on the forums. Best Regards, Håvard Njåstad Njastad.com
 1 user thanked Thremir for this useful post.
Thanks: 17 times Was thanked: 5 time(s) in 4 post(s)
+1 If we can manage to highlight i.e five of the latest stories, I`d definitely buy it. I may be asking for a bit much, but if it could autoupdate i.e the five latest stories and replace those with the old ones, that would be awesome! Thremir wrote:rdally wrote:is there a way to show more than just one story item at a time? For example, by 'highlighting' multiple lines in the Story List or choosing to show the 5 latest stories. We'll put that on the Feature Request list and keep you updated via mail or here on the forums. Best Regards, Håvard Njåstad Njastad.com
Joined: 8/13/2014(UTC) Posts: 9  Location: Poços de Caldas - BRASIL Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Really the stories not refresh automatically, made the purchase and I'm disappointed. Does not work yet. I am awaiting a response from them.
The staff solved my problem. Were very attentive. These Norwegians brothers are really incredible!
