PauMedia
#1 Posted : Monday, April 28, 2025 6:19:44 PM(UTC)
PauMedia
Spain
I would like to ask if there are any plans to enable custom audio matrix configuration for an input via the API-not just through predefined audio routing presets, but with full flexibility to set the routing manually.
JacobLarsson
#2 Posted : Monday, April 28, 2025 9:19:28 PM(UTC)
JacobLarsson
Norway
+1
ryxyz
#3 Posted : Monday, April 28, 2025 11:27:35 PM(UTC)
ryxyz
Was thanked: 11 time(s) in 4 post(s)
+1
InstantReplayGO
#4 Posted : Wednesday, April 30, 2025 3:40:53 AM(UTC)
InstantReplayGO
Brazil
Was thanked: 8 time(s) in 3 post(s)
On github have a lot cool projects to vmix and audio matrix is this one.
Good projects
1 - https://github.com/jenss...dio-matrix-vmix-electron
2 - https://github.com/MulticamSystems/vMixAudioMatrix
I hope help you
usermedia
#5 Posted : Monday, September 29, 2025 7:41:01 PM(UTC)
usermedia
Spain
Hi! No, I mean being able to change the audio matrix of an input through the API. For input sources that have more than one stereo audio.
Guest (4)
