2 Pages12>
InstantReplayGO
#1 Posted : Saturday, April 26, 2025 3:12:21 AM(UTC)
InstantReplayGO
Brazil
Was thanked: 8 time(s) in 3 post(s)
It is very important to have a shortcut to search for replay clip name tags with the intention of always not using the mouse and keyboard in the operation, focusing on the use of controllers and making the operation more dynamic:
- ReplayFindTag (triggers the focus on the replay search bar)
- ReplayFindTagName (enter the name Goal for example and it returns all the clips on the replay manager screen)
- ReplayFindTagNameReset (remove the tag from the search, returning all the clips to the screen again)
thanks 4 users thanked InstantReplayGO for this useful post.
eduardocfs on 4/26/2025(UTC), thyag0_chz on 4/26/2025(UTC), eddysangalli on 4/26/2025(UTC), otisrib64 on 5/2/2025(UTC)
samirbridi
#2 Posted : Saturday, April 26, 2025 3:34:08 AM(UTC)
samirbridi
Brazil
+1
Richard
#3 Posted : Saturday, April 26, 2025 3:40:54 AM(UTC)
Richard
Brazil
+1
recrieprodutora
#4 Posted : Saturday, April 26, 2025 5:19:21 AM(UTC)
recrieprodutora
Brazil
Excellent! This would make using replay even more practical.
DaiiiCarol
#5 Posted : Saturday, April 26, 2025 7:31:14 AM(UTC)
DaiiiCarol
Brazil
+1
Danilo Reis
#6 Posted : Saturday, April 26, 2025 7:40:26 AM(UTC)
Danilo Reis
Brazil
+1
duduxweb
#7 Posted : Saturday, April 26, 2025 7:40:50 AM(UTC)
duduxweb
Brazil
+1
arthurlimahd
#8 Posted : Saturday, April 26, 2025 8:08:13 AM(UTC)
arthurlimahd
Brazil
+1
eduardocfs
#9 Posted : Saturday, April 26, 2025 9:37:49 AM(UTC)
eduardocfs
Brazil
Was thanked: 19 time(s) in 8 post(s)
+1
eddysangalli
#10 Posted : Saturday, April 26, 2025 11:19:52 AM(UTC)
eddysangalli
Brazil
+1
Thank you, Professor InstantReplayGO. The Brazilian master of replay.
MelitoWe
#11 Posted : Saturday, April 26, 2025 12:56:13 PM(UTC)
MelitoWe
+1
#12 Posted : Saturday, April 26, 2025 6:27:07 PM(UTC)
Would you not need the keyboard for that ? would this benefit operation speed instead of just clicking the little arrow and pick from the list?
InstantReplayGO
#13 Posted : Saturday, April 26, 2025 10:46:49 PM(UTC)
InstantReplayGO
Brazil
The concept is thinking about hardware of replay on broadcast (EVS, Dynno, Mira, Orad,3play) when use mouse only thing very necessary, all operation is on remote controller. We are use NEOiD Replay Pro on Brasil but is SK-420 San-Keys website, it is a better replay controler to vMix on this days. More than JL cooper, Skahooj, XKeys. Tyst Vídeo, Winwet,PMJ, I test all controllers to vMix and this SK-420 is a better of all
#14 Posted : Sunday, April 27, 2025 12:19:45 AM(UTC)
listing hardware ( or promoting it ) still doesnt explain the benefit, the way you describe one still would have to go to the keyboard to type in what you are searching for , Only difference is the search box would be open with a shortcut .... and yes instead of typng one could select from a dropdownlist which would need the mouse again, and how you you select then within the filtered list , I assume a mouse not?. To me this feels counter productive especially if the operation needs to be fast paced . So far to me it doesnt make sense unless i am missing something
InstantReplayGO
#15 Posted : Sunday, April 27, 2025 1:56:57 AM(UTC)
InstantReplayGO
Brazil
I understand you Doggy, for the people replay operator Make sense use only remote controller, that sk-420 have a shift so active for example ReplayFindTagName value=goal On button and ReplayFindTagName value=fault, ReplayFindTagName value=offside it’s more easy find this clips without mouse and keyboard on live operations, reduce information level when fix eyes on controller only.
Other replay operators understand this value.
#16 Posted : Sunday, April 27, 2025 2:56:11 AM(UTC)
OK, This is totally different than your initial request , Here you want a shortcut with a predefined value that filters the events accordingly. This is not at all the same as a shortcut to open the selection box in order to type a search value!!!
Why Not just ask for a shortcutfunction to filter on value ? then any controler can be used instead of just the sk-420
FYI i dont fix my eyes on a controller (typist do not look at keyboard either) but instead on the monitor where all the info (to select) is
What are you emplying here Professor InstantReplayGO (not named by me but your followers ;-) )?
InstantReplayGO
#17 Posted : Sunday, April 27, 2025 3:03:53 AM(UTC)
InstantReplayGO
Brazil
Are you a Studiocoast Dev? Do you read correctly my “suggestion”?
#18 Posted : Sunday, April 27, 2025 3:29:27 AM(UTC)
Ssst..
A simple autohotkey script called from vMix can do what you want ;-)
thyag0_chz
#19 Posted : Friday, May 2, 2025 6:52:15 AM(UTC)
thyag0_chz
Brazil
+1
otisrib64
#20 Posted : Friday, May 2, 2025 9:04:49 AM(UTC)
otisrib64
Brazil
Guest (11)
2 Pages12>
