Feature Requests
Full vMix Call Control via API (Create/Reset/Disconnect Calls, Retrieve Codes)
Hi vMix team and community
I’d like to request some extended functionality related to vMix Call and the API. As we build custom interfaces for producers/operators, it would be amazing to have better programmatic control over the lifecycle of calls.
Here are some specific features that would be incredibly useful:
VideoCallResetPassword Generates a new password/link for an existing Call input (same as clicking “Reset Link” in the GUI).
AddInput&Value=Call Allows dynamic creation of Call inputs via API. It would be even better if we could pass optional parameters like:
Return video source (Output1/2/etc)
Return audio (BusA/Master/etc)
Bitrate / resolution preferences
Retrieve the current Call password via XML API At the moment, the password is hard to extract or not exposed clearly in the XML. This would help a lot in managing invitations programmatically.
Additional ideas Managed queue of callers per input: Allow multiple callers to attempt connection to the same Call input, and queue them (or give producers the option to accept the next one).
"Channel not available" screen: When a Call input is already in use, new callers should receive a customizable “Channel busy / not available” message instead of simply overriding the previous caller.
I understand that many of these controls are available in the GUI or through manual work, but exposing them via API would be a game-changer for people building automated, remote-friendly workflows.
Best regards, Óscar Gómez
Joined: 2/23/2023(UTC) Posts: 89  Thanks: 30 times Was thanked: 20 time(s) in 6 post(s)
+1 for better API integration but, vmixcall is and was always a simple (but expensive) add on. I believe the simplicity won't change and also limits it. But times/perspectives could change as well.
Joined: 9/3/2021(UTC) Posts: 10  Location: LONDON Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Feature Requests
