Hi guys When I open the first vmix all is fine the problem starts as soon as I open the 2nd instance of the vmix the other instance that now gone to background FPS drops and says GPU overloaded when I switch to that instance All things returns OK and the other one throttle
The PC is i7-265K and GPU 3080 it's not the PC weakness because I open the 2nd Instance blank with no input
anyone faced this Problem?
Found it
the reason is that I have a Decklink Quad 2 with 8 outputs , so I control output 1-4 from first Vmix and 5-8 from the second when both Externals is on the other Vmix Falls
so any idea ?
Joined: 1/13/2010(UTC) Posts: 5,311  Location: Gold Coast, Australia Was thanked: 4711 time(s) in 1615 post(s)
Please note, multiple instances of vMix is not supported. The checkbox to enable it is hidden behind Advanced Settings with a specific warning not to enable for this very reason. There is only a single audio mixer per computer in vMix, so things like External Output etc that rely on audio will not work properly.
Sorry about that.
