mcgeem1
#1 Posted : Tuesday, April 8, 2025 6:55:53 AM(UTC)
mcgeem1
Team
I am having an issue with a computer where we are streaming right along then about 1.5 or 2 hours into the stream, our streams to YouTube & Facebook turn orange, then a message pops up saying "you are on a metered network" then my connection drops. We are not on a metered network along with Ethernet settings, "metered" is turned to OFF. This is very frustrating for I even installed a new Unifi (Ubiquiti) Dream Machine Pro; things are working then you get this message the 'wired connection' drops and it pops to WIFI. In filing my support with vMix, they see they see a DNS or name resolution issue but again I just installed a whole new network. Have any of you seen this behavior with vMix or PCs or should I switch the Ethernet setting to 'Metered network'. Not sure what to do here!!! Any advise, appreciated
kross
#2 Posted : Thursday, April 17, 2025 1:26:12 PM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
Hmm I've not seen this before, but my understanding is that even when set to "metered" it shouldn't kick you off, unless you have a data limit set. Go to your network status control panel page, then click on "data usage". From there you should be able to remove a data limit if one has been enabled.
