offroadmediagroup
#1 Posted : Thursday, April 3, 2025 3:30:15 PM(UTC)
offroadmediagroup
If you select multiple layers, let's say 20 layers, of boxes that you want to expose their color values to the data on the vMix side, you have to unhide them. So you select them all and uncheck the box... none of the layers will be changed after the checkbox has changed.
thanks 1 user thanked offroadmediagroup for this useful post.
Stealth77 on 9/3/2025(UTC)
