michaelthomasbrennan
#1 Posted: : Thursday, March 27, 2025 7:20:16 PM(UTC)
Would it be worth creating a vMix Automation forum for those of us working specifically with vMix and automation rundown/production software. I'm working with Tinkerlist Cuez Rundowm and Cuez Automator and there are very specific issues that arise using vMix and Cuez together.
Plus integration with Dante and Stream Deck
Would anyone else be interested or would this be a forum where I'd be talking to meyself :-)
Michael
TJPerkins
#2 Posted : Saturday, March 29, 2025 4:28:19 AM(UTC)
TJPerkins
Canada
Count me in! I can repost the scripting I've pieced together from everyone's input...
#3 Posted : Monday, March 31, 2025 9:12:28 PM(UTC)
Great - I'm very busy this week - but have time next week to document what Ive done here at the uni with configuring vMix and Cuez automator - I have loads more to do - dante - incoming calls etc...
It would be good to known what you are doing in more detail.
It would be good to to hear back from you
TJPerkins
#4 Posted : Tuesday, April 1, 2025 2:44:36 AM(UTC)
TJPerkins
Canada
My latest project is to automate a radio podcast…three hosts in the studio, each host has their own camera and mic inputs. I’ve set it up so that vMix automatically cuts between the cameras depending on who is speaking, with a built-in delay in case two people talk at once. I also want to add a lower third title with their name and Instagram handle from time to time, but I’ll save that for another post.
It’s worth noting that I haven’t been able to fully test it out yet (I’m in Vancouver and the show is in Toronto), but I’m hoping to at least have everything set up this week so I can give it a good workout. I will say that initial testing has been quite successful!
Here is the setup:
• 3 camera inputs, labeled CAM 1, CAM 2 and CAM 3
• 3 mics (labels aren’t important, but they’re MIC 1, 2 and 3)
• 3 audio bus inputs, labeled BUS A, BUS B and BUS C
The buses are how I turn the AutoTake on and off…sending the mics to the three Buses (Mic 1 to Bus A, etc) turns it on. This is so I can halt the AutoTake while adding a lower-third title.
Here is the scripting for AutoTake:
Code:
Do While True
dim BusALevel As String
dim BusBLevel As String
dim BusCLevel As String
dim VmixXML as new system.xml.xmldocument
VmixXML.loadxml(API.XML)
dim BusANode As XmlNode = VmixXML.selectSingleNode("/vmix/inputs/input[@title=""BUS A""]")
dim BusBNode As XmlNode = VmixXML.selectSingleNode("/vmix/inputs/input[@title=""BUS B""]")
dim BusCNode As XmlNode = VmixXML.selectSingleNode("/vmix/inputs/input[@title=""BUS C""]")
BusALevel = (VmixXML.SelectSingleNode("/vmix/audio/busA/@meterF1").Value)
if BusALevel > "0.05"
  API.Function("CutDirect",Input:="CAM 1")
sleep(5000)
End if
BusBLevel = (VmixXML.SelectSingleNode("/vmix/audio/busB/@meterF1").Value)
if BusBLevel > "0.05"
  API.Function("CutDirect",Input:="CAM 2")
sleep(5000)
End if
BusCLevel = (VmixXML.SelectSingleNode("/vmix/audio/busC/@meterF1").Value)
if BusCLevel > "0.05"
  API.Function("CutDirect",Input:="CAM 3")
sleep(5000)
End if
Loop
It’s worth noting that I also cranked the gain of the three busses all the way up, in case someone speaks quietly.
Many thanks go out to everyone who has helped me (voluntarily or otherwise) nail down the VB scripting!
thanks 2 users thanked TJPerkins for this useful post.
nikosman88 on 4/3/2025(UTC), bulent_atlas on 4/15/2025(UTC)
TJPerkins
#5 Posted : Wednesday, April 2, 2025 4:09:15 AM(UTC)
TJPerkins
Canada
And as promised, here is how I handle the name titles:
• There is one title input with two lines of text for name and Instagram handle
• Text fields are assigned to a data source which uses a simple .csv file
• Depending on which camera is on Program, the script will:
o Pause the AutoTake (by turning off audio sent to Bus A, B and C)
o Change the Data Source to the correct host name/handle
o Add the Title for 4 seconds
o Take out the Title and wait another second
o Resume AutoTake
Using a Stream Deck anyone (most likely the main host or a producer) can hit the same button while anyone is talking and the correct name title will appear for that host.
Here is the code:
Code:
dim xml as string = API.XML()
dim InputActiveName as string = ""
dim activeinput as string = ""
x.loadxml(xml)
activeinput = (x.SelectSingleNode("//active").InnerText)
InputActiveName = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@title").Value)
if InputActiveName = "CAM 1"
   API.Function("AudioBusOff",Value:="A",Input:="CAM 1")
   API.Function("AudioBusOff",Value:="B",Input:="CAM 2")
   API.Function("AudioBusOff",Value:="C",Input:="CAM 3")
   Sleep (100)
   API.Function("DataSourceSelectRow",Value:="CSV,Sheet1,2")
   API.Function("OverlayInput1In",Input:="4")
   Sleep (4000)
   API.Function("OverlayInput1Out")
   Sleep (1000)
   API.Function("AudioBusOn",Value:="A",Input:="CAM 1")
   API.Function("AudioBusOn",Value:="B",Input:="CAM 2")
   API.Function("AudioBusOn",Value:="C",Input:="CAM 3")
elseif InputActiveName = "CAM 2"
   Sleep (100)
   API.Function("DataSourceSelectRow",Value:="CSV,Sheet1,1")
   Sleep (4000)
   Sleep (1000)
elseif InputActiveName = "CAM 3"
   Sleep (100)
   API.Function("DataSourceSelectRow",Value:="CSV,Sheet1,0")
   Sleep (4000)
   Sleep (1000)
end if
Roy Sinclair
#6 Posted : Thursday, April 3, 2025 7:22:18 AM(UTC)
Roy Sinclair
Code:
Do While True
Why are these three lines in that script? You do not use any of the three variables created by those lines anywhere else in the script.
TJPerkins
#7 Posted : Thursday, April 3, 2025 7:45:23 AM(UTC)
TJPerkins
Canada
That's a very good question...it's actually a bit of a Frankenscript, derived from previous experiments, so for all I know they're not needed.
HOWEVER...
I tried taking them out, and it somehow punched up another camera when no one was talking on it, even when AutoTake was temporarily suspended while I added a name title.
So for now I'm keeping those three lines in.
Here's another thought...is there a way to add time to the script, so that someone needs to speak for, say, a minimum of 2 seconds before it bothers cutting to that camera? I'm thinking it would be nice to "filter out" someone just saying a word or two (Yep, Uh huh, etc).
nikosman88
#8 Posted : Thursday, April 3, 2025 7:55:33 AM(UTC)
nikosman88
Greece
Was thanked: 93 time(s) in 89 post(s)
Im trying also to understand how this script work. I have my audio in the picture i attach. autotake.png (114kb) downloaded 15 time(s).
Is this correct? The thing is that in this way the script loop after 5 sec between the 3 cameras and it ignores completelly the level of mics
Other than this,vmix has built in basic audio triggers. So if you do a trigger in Mic 1 input-->OnAudioMeterDB18 or lower, and then -->cut-->cam1 and delay 2000 it will cut to cam 1,after 2 sec of the mic 1 that reaches 18db. Same for mic 2 for cam 2,mic 3 for cam 3 and no need to use audio buses.
But your thought is excellent,if can work ok,because we can have more presize in the levels
Edit
Roy Sinclair has right.You read the correct values but then in the "if" you write wrong value to be checked. The fixed script that seems to work for me is this
Code:
Do While True
BusALevel = (VmixXML.SelectSingleNode("/vmix/inputs/input[@title='Bus A']/@meterF1").Value)
sleep(5000)
End if
BusBLevel = (VmixXML.SelectSingleNode("/vmix/inputs/input[@title='Bus B']/@meterF1").Value)
sleep(5000)
End if
BusCLevel = (VmixXML.SelectSingleNode("/vmix/inputs/input[@title='Bus C']/@meterF1").Value)
sleep(5000)
End if
Loop
Some remaining problems is that if no-one talks to choose a general shot and the 1-2" "cough" problem. AI suggested something with a timer inside the script but doesnt work as supposed. But as idea is very good and thanks for this
Roy Sinclair
#9 Posted : Thursday, April 3, 2025 10:36:56 AM(UTC)
Roy Sinclair
HOWEVER...
If your script is checking the volume levels continually then where you see they start talking you take the current time in milliseconds, add 2000 to it and keep checking both the volume and the time until the time is equal or greater than the the time you added 2000 to. You can keep your loops from being too intensive on the CPU by waiting for 50 milliseconds "Sleep(50)" as a part of each loop.
TJPerkins
#10 Posted : Saturday, April 5, 2025 1:33:19 AM(UTC)
TJPerkins
Canada
Is this correct?
I named my busses BUS A, BUS B, BUS C (all caps), but since those three lines in the code don't seem to be needed, then it shouldn't matter.
And again, I also raised the audio gain in the busses all the way:
You can also adjust the "listen level" in the code:
Code:
If you need it to be more sensitive, try changing the 0.05 to 0.001 or even lower (I pretty much pulled 0.05 out of thin air...it worked for me, but every scenario will always be a bit different).
Yep, I tried that first, but when these podcast hosts get going they constantly step on each other, and you end up with cameras flickering back and forth (even adding a delay didn't help).
That's a very good idea! But in our case, these hosts never shut up so I don't think that will be a problem. But now that you said it, you got me thinking that they might have a guest or a caller some day, so I will need to factor that in somehow.
Thank you for your input!!
TJPerkins
#11 Posted : Saturday, April 5, 2025 1:35:20 AM(UTC)
TJPerkins
Canada
I'll give it a shot and get back to you...thanks!!
TJPerkins
#12 Posted : Saturday, April 5, 2025 3:46:12 AM(UTC)
TJPerkins
Canada
Okay, that sort of works...except I keep running into the same problem where it goes to another camera even though they only said one or two words (just a second or two later).
Here is what I'm aiming for:
Code:
Function holdYourhorses()
Dim Start_Time As DateTime
Dim Stop_Time As DateTime
Dim Elapsed_Time As TimeSpan
'yada yada if Elepsed_Time is greater than 2 seconds,
'go through the motions of autotake
'obviously this is where I totally get into the weeds
End Function
One side benefit to this is I can then shorten the Sleep(5000) to one or two seconds.
nikosman88
#13 Posted : Saturday, April 5, 2025 6:29:52 AM(UTC)
nikosman88
Greece
Is this correct?
Code:
Thanks. This gives to me too much background noise. Also i have to apologize for the script. Your script as it is,work also ok. The difference between yours and mine is that you read from the vmix API the buses from their direct section instead of my way from inputs. The reason that didnt work properly at first was a vst3 plugin and some other audio routing i have.
So the main question here is. How can we prevent the script to not react in small words or "cough/neck clean" from the talent
TJPerkins
#14 Posted : Wednesday, April 9, 2025 7:41:15 AM(UTC)
TJPerkins
Canada
That's exactly what I'm working on next...and by that I mean I'm asking people who know a lot more about Visual Basic than I do.
I know there's a way to measure time using something like this:
Code:
...then make a function that says "only go to another camera if Elapsed_Time is greater than two seconds"...somehow (I'm still looking up other coding examples to see if anyone has written something similar).
#15 Posted : Friday, April 11, 2025 7:44:55 PM(UTC)
This is great stuff - now got my head out of work for the moment: I thought i'd set our what I'm doing with vMix here at the University:
First - I love NDI - its so flexible and adaptable and configurable
We have a Tricaster 2 Elite with Dante Virtual Sound Card - 4 x PTZ cameras, green screenstudio, Allen & Heath SQ5 running the Dante card, Dante Controller, CueScript Prompter, Flowics single channel GFX, 4 channels of LiveU (NDI out), Sienna NDI Router/Sienna Processing Engine and Cuez Rundown and Cuez Automator - I'm in the process of reconfiguring it all to work with vMix instead of the Tricaster - Why? Because I find vMix easier to configure for the different Newsday scenarios we have to to run; much simpler than the TC2 and allows we to progamme very complex effects though Cuez Automator.
So far I have build 95% of the automation block in Cuez for vMix
Reconfigured the prompter system to work with Cuez rundown prompter - much simpler and less prone to update error that using using CueScript through the MOS Gateway.
Added the vMix outputs to the Sienna router
My next big task is to reconfigure the audio over Dante for vMix - and vMix deals with audio in a more complex structure manner that the Tricaster.
If anyone needs help or wants to discuss configuring Cuez Automator blocks with vMix drop me a line.
Guest (4)
