I use Vmix with companion and often have a lot of videos that change very often. I use the List Item Name on the button, which is fine but I end up with a button that says MY_Image_Name_R3_325.mov (or whatever the graphics team names it) as the button name. Vmix gives you that ability to name it somethign simpoer but it doesn't expose that name in the API so that Companion can pick it up.
Hi. What you say is true and false same time. True that in the list selected index the name remains the same even if we change it by using the Edit button in the list. But also false because the info you need is exposed in the "Title="Mylist - myrenamed item". So yes the info is there but the companion developer module dont include this $list_title_variable in the program. I also need it and i hope in a next version he will include it or vmix team make the change in the list part
Yes please! I would also need the renamed list items exposed in the API, because I often need to trigger items from lists via Companion, and the long file names are often really hard to read or distinguish.
Joined: 2/7/2024(UTC) Posts: 197  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
+1! Please expose the list filenames, selecting a list item by number is only handy if the list never changes
