TurtleNaz74
#1 Posted : Thursday, March 13, 2025 5:59:39 AM(UTC)
TurtleNaz74
Can anyone please help me with my over exposure problem? We've just implemented a new ptz camera for worship and it's brightness is way too much. When I try to change it in the camera menu, all it does is make it darker without actually toning down the exposure. All VMIX can tell me to do is work on the color grading. I'm not really understanding which route to take. Any help would be greatly appreciated! Thank you!
WaltG12
#2 Posted : Thursday, March 13, 2025 6:44:38 AM(UTC)
WaltG12
If the camera doesn't let you adjust the ISO level in-camera & you can't reduce the lighting to compensate, I'd suggest the simplest fix would be to get a new camera.
As you note, once you have the image, there are ways of darkening it, but, as you also note, that's not really the same thing.
TurtleNaz74
#3 Posted : Thursday, March 13, 2025 7:31:44 AM(UTC)
TurtleNaz74
Thanks for that, but I DID just purchase a new camera. About $2000 worth. I feel there should be a fix. A new camera will just come with it's own new set of issues, anyway.
WaltG12
#4 Posted : Thursday, March 13, 2025 7:38:31 AM(UTC)
WaltG12
I understand that's not the answer you want to hear, but it's the truth.
The camera turns light into pixels.
If those pixels are damaged--such as being under or overexposed--there's not much you can do to those pixels to get them back to what they're supposed to be.
If your camera is overexposing your image, the options really are to either change the camera settings so it doesn't do that anymore or reduce the amount of lighting to match what the camera is apparently expecting.
If neither of those are feasible, you're really only left with the option of getting a different camera that either allows you to change those settings or is hardcoded to expect the proper amount of ambient light.
thanks 1 user thanked WaltG12 for this useful post.
TurtleNaz74 on 3/13/2025(UTC)
kross
#5 Posted : Sunday, March 16, 2025 7:12:38 AM(UTC)
kross
Was thanked: 44 time(s) in 43 post(s)
I think you need to provide the camera make and model, to get any meaningful replies about how to adjust the exposure level in the camera.
