Joined: 3/12/2025(UTC) Posts: 1  Location: Dubai Thanks: 1 times
The timer moves left and right while counting down, for example if you are putting the countdown in a frame, it won't be in the exact same position when it switches numbers, it keeps moving some pixels left & right depending on the number shape. Is there a way to have it fixed, like the number being changed won't be effecting other numbers position.
Not sure if i made any sense xD, appreciate any help!
Originally Posted by: Y1do  The timer moves left and right while counting down, for example if you are putting the countdown in a frame, it won't be in the exact same position when it switches numbers, it keeps moving some pixels left & right depending on the number shape. Is there a way to have it fixed, like the number being changed won't be effecting other numbers position.
Not sure if i made any sense xD, appreciate any help! Use a monospaced font
