Hi!
Does anyone know if telestrator page accepts query strings like ?fullscreen=true ? ive tried this and others and it didnt work. Does anyone know proper string or it is even enabled. it would be great to have options like fullscreen on/off drawing on/off latency normal/low pointer on/off
Originally Posted by: bscav  Hi!
Does anyone know if telestrator page accepts query strings like ?fullscreen=true ? ive tried this and others and it didnt work. Does anyone know proper string or it is even enabled. it would be great to have options like fullscreen on/off drawing on/off latency normal/low pointer on/off Did you find any in the shortcut reference lists ?
Originally Posted by: doggy  Originally Posted by: bscav  Hi!
Does anyone know if telestrator page accepts query strings like ?fullscreen=true ? ive tried this and others and it didnt work. Does anyone know proper string or it is even enabled. it would be great to have options like fullscreen on/off drawing on/off latency normal/low pointer on/off Did you find any in the shortcut reference lists ? It's not a vmix shortcut that I could reference. I'd like to append the url for the telestrator so it opens in fullscreen with other set parameters. So the url would look like http://vmixip:port/telestrator/? fullscreen=true
