I evaluate vMix, I created a title in the designer with multiple image placeholder and multiples textfields. Now I am trying to change the images and the text via the API.
I am able to select the right text field via the selectedName parameter, but for the SetImage function, this parameter seems not to work. I am only able to change the first image in the title. Not the second and not the third.
Is there any reason why selectedName is noch working for SetImage function? Or is there another parameter for selecting the image?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Is there any reason why selectedName is noch working for SetImage function? Or is there another parameter for selecting the image? Code:API.Function("SetImage",Input:="images.gtzip",SelectedName:="Image2.Source",Value:="D:\blabla.png")
Hi, I already searched, but as I said I want to set the image path via API from an external solution. Not via an internal script. Simple example with API calls: the setText function works as expected, this API Call sets a new text for the selected TextBlock1.text http://127.0.0.1:8088/api/?Function=SetText&Input=test&SelectedName=TextBlock1.text&Value=Test The SetImage function should work identically if I trust the documentation: https://www.vmix.com/hel...utFunctionReference.htmlBut it doesn't: This call does nothing: http://127.0.0.1:8088/api/?Function=SetImage&Input=test&Value=C:/path/to/my/image/md.png&SelectedName=heim.source This call changes the first image: http://127.0.0.1:8088/api/?Function=SetImage&Input=test&Value=C:/path/to/my/image/md.png It looks like the SelectedName property is not working for the SetImage function. Of course, I created the titel via GT Designer and added Image placeholders.
Mhh also tried selectedValue but its not working too: I have 2 images: heim.source and gast.source, only this call is changing a image: http://127.0.0.1:8088/api/?Function=SetImage&Input=test&Value=C:/path/eb.png&SelectedValue=heim.source This not: http://127.0.0.1:8088/api/?Function=SetImage&Input=test&Value=C:/path/eb.png&SelectedValue=gast.source But it's strange, the firsrt call wit SelectedValue=heim.source is changing the image for gast.source ^^ If I call wirh SelectedValue=gast.source nothing happens. Both images are visible in the title editor.
Originally Posted by: Bias89  Hi, I already searched, but as I said I want to set the image path via API from an external solution. Not via an internal script. Simple example with API calls: the setText function works as expected, this API Call sets a new text for the selected TextBlock1.text http://127.0.0.1:8088/api/?Function=SetText&Input=test&SelectedName=TextBlock1.text&Value=Test The SetImage function should work identically if I trust the documentation: https://www.vmix.com/hel...utFunctionReference.htmlBut it doesn't: This call does nothing: http://127.0.0.1:8088/api/?Function=SetImage&Input=test&Value=C:/path/to/my/image/md.png&SelectedName=heim.source This call changes the first image: http://127.0.0.1:8088/api/?Function=SetImage&Input=test&Value=C:/path/to/my/image/md.png It looks like the SelectedName property is not working for the SetImage function. Of course, I created the titel via GT Designer and added Image placeholders. pay attention to the use of capitals :Source instead of source Also part of the link especially the value should be URL encoded C:/path/to/my/image/md.png should be C%3A%2Fpath%2Fto%2Fmy%2Fimage%2Fmd.png see : https://forums.vmix.com/...Web-API-Script#post51481
