Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Hi everyone, I'm facing an issue and hope someone can assist. I've configured certain files to have their audio routed to both the Master output and Audio Bus B.
I've also set up Zoom to use Audio Bus B so that my presenters can hear audio clips during live outputs. However, Zoom keeps disabling the audio, showing the audio icon with a strikethrough.
Does anyone know how to fix this or guide me on the proper setup to avoid this issue?
Thanks.
Can it be tht there is some noise supression enabled in the zoom client. I'm not using zoom but it's the root in Teams meetings that I use.
Originally Posted by: mavik  Can it be tht there is some noise supression enabled in the zoom client. I'm not using zoom but it's the root in Teams meetings that I use. Thanks for responding, not that I can see. The icon for the volume is muted and I just can't see where to turn it on!
Joined: 10/1/2021(UTC) Posts: 6   Location: Berlin Thanks: 1 times
If you right click on the zoom Input in vMix, go to "Meeting Settings" und click "UnMute Self" - your Audio must be enabled and everyone should hear you.
