Tim P.
#1 Posted : Monday, March 3, 2025 2:00:40 PM(UTC)
Tim P.
I am deciding about moving to Vmix from years with Wirecast. I will be using Vmix for live streaming sports productions. As you may know, Wirecast has five separate layers for assets. Since the cameras get switched in my external Roland switcher, I tend to put the camera feed on the bottom layer and it basically never gets turned off. So all other assets go on layers above and once you push the cameras live, they stay live until you take them off. This means if you play a few commercials, after the last commercial, the camera feed is already there underneath. Meaning I do not need to select the camera to put it in the preview and then push it live again.
In learning Vmix, it seems if I have the camera input live, playing a commercial would take the cameras away. So if I wanted to go back to cameras at the end of a few commercials, I would need to select the camera input, place it in the preview and push it live. During a 4 hour football broadcast, that is a lot of selecting the camera feed!
Is there a way in Vmix to recreate the Wirecast of approach of always having the camera input active etc...?
P.S. We also have a lot of commercials that only consist of a logo with a voiceover. For these we have a semi-transparent gray layer on the screen which allows for the live camera feed to be seen underneath. At this point, to recreate this I assume I would need to have the camera input be part of every commercial's layers?
Thanks for your help
dmwkr
#2 Posted : Monday, March 3, 2025 9:02:53 PM(UTC)
dmwkr
I am not familiar with Wirecast, but would advise to get to know vMix better instead of copying your Wirecast workflow. You will be handcuffing yourself sooner or later.
E.g. triggers: https://www.vmix.com/kno.../115/how-to-use-triggers
Overlays: https://www.vmix.com/kno.../212/how-to-use-overlays
mavik
#3 Posted : Tuesday, March 4, 2025 12:12:28 AM(UTC)
mavik
As previous beta tester of wirecast I can highly recommend switching to vMix. vMix has a different concept than wirecast. vMix is more comparable with a hardware mixer. So I highly recommend getting used to the vMix way of doing.
But, there is a way of corse to mimic the wirecast way. You put your cam to live and whatever you want to show above it so to say -like the layers in wirecast- you use the overlays 1-4 for that. One thing to remember with vMix is that you have access to everything to be controlled with shortcuts or commands. Make use of it as is simplyfies productions a lot. Every input can have multiple layers (10) as well. So another option would be to add the camera and put the other inputs as a seperate layer into that shot and switch layers on/off with a shortcut. There are also miniMixes that can be use as overlay or in layers.
Have a look at vmix tutorials to give a an idea how to use overlays and layers.
Tim P.
#4 Posted : Tuesday, March 4, 2025 6:12:55 AM(UTC)
Tim P.
Thanks for your replies. One the main reasons I am looking at Vmix is that the program seems to be actively developed.
As many, I am a one-man-band so I need things to very very streamlined to be able to do what I do. That does not always mean automation though as sports broadcasting is quite fluid. Some of my work would easily fit right into Vmix. Other jobs are larger in nature with 15+ sponsors. Hence the need for the ability to juggle a lot of assets and play them easily.
Right now in Wirecast, if I have a lot of commercials to keep track of, I can see them all on a layer or two. This makes them easy to select into the preview and go live. My concern with having so much stacked in layers or special mixes etc... is that I will not be able to see them without sacrificing screen real estate.
So to clarify, there is no way to keep an input live (like cameras) and in the program window? What I am most concerned with is running two commercials and forgetting to load the cameras back into preview when the ad is finished. Yes, I will adjust but would like to ask.
Also, how would you solve the scenario where the cameras stay live underneath the transparent commercials?
Thanks!
mavik
#5 Posted: : Tuesday, March 4, 2025 7:23:39 AM(UTC)
mavik
Just follow as I said.
1. set you cam into program.
2. add other sources like commercials, ads, sponsors or what have you.
3. Under each input you see numbers. 1 2 3 4. Click these numbers (turns red) and the input will be shown above the program (cam from #1).
4. click the number again and the red indicator goes off and your cam is visible again.
If you have a lot of clips you can load them in a list.
You can set a trigger (on complete) to turn the overlay (1 2 3 4) off. This makes just one click to overlay an input and it goes off magically when it ends.
Tim P.
#6 Posted : Tuesday, March 4, 2025 8:35:04 AM(UTC)
Tim P.
Thank you for your reply. Since the numbers are 1,2,3 & 4, I thought I would be limited to only four commercials using overlays. But what you are saying is to temporarily turn one of the overlay channels on (given there is nothing else set to that overlay channel that will show) and it will bring the commercial up as I wanted.
But, this seems like a direct to air button press correct? Bypassing the preview window.
Any ideas about the transparent commercial approach? I guess I could have the transparent gray assigned to overlay 1 so when I press overlay 1 to play a commercial, the gray would play as well. I am unclear about layer stack order in this instance. I watched the Vmix video on overlays but I do not remember anything about layer order.
Roy Sinclair
#7 Posted : Tuesday, March 4, 2025 9:21:49 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
A possible way to do this is to use the Layers each input comes with with vMix mixes. Your camera will be the Layer 1 by default so merely add a vMix input as layer 2 and default that mix to a "clear" image that doesn't alter the camera image (a zeroed alpha image). Then you can set your advertisements up in list inputs for each ad break that play the ads serially from the list in the Mix used for layer 2 and make that clear image be the last item in the list so the ad break ends by the images over the camera going back to the "clear image" input. Then set up triggers so when the clear image is replaced by an add the sound for the program is cut off and when the clear image is restored so is the program sound.
Tim P.
#8 Posted : Tuesday, March 4, 2025 12:20:21 PM(UTC)
Tim P.
Thanks. I will try that out. Vmix seems to have a lot of ways to accomplish things.
BTW, I tried playing an add using the "number 1" overlay approach and it plays, but I am not getting audio with playback. Which does not surprise me since overlays are mean for lower thirds etc... Unless there is a way to tell it to play the audio.
kross
#9 Posted : Tuesday, March 4, 2025 3:37:08 PM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
Under the particular input that you are activating, there is a button labeled "audio". Make sure it is enabled (green). Normally this is the default when you add new media inputs, but you may have accidentally turned it off during your experiments. If you still don't get any audio, go to the audio mixer and make sure it is outputting to the master audio channel.
Tim P.
#10 Posted : Wednesday, March 5, 2025 12:10:13 AM(UTC)
Tim P.
Thanks I will look at it today. When the video was put into preview and taken live it played audio. So I believe the audio button was engaged.
