knbPixels
#1 Posted : Tuesday, March 4, 2025 8:12:53 AM(UTC)
knbPixels
I know I've encountered this before, but can't remember if there is a solution or not. When you create an "OnTransitionIn" trigger on input A that's used on a layer of another input B, and transition in that second input, the trigger doesn't fire because input A is just on a layer.
I tried "Flatten" on both inputs and it didn't help. Is there a workaround?
mavik
#2 Posted : Tuesday, March 4, 2025 5:30:57 PM(UTC)
mavik
Of course it's not working. You deal with input B and not A. So triggers are fired for input B and not A. You can copy the trigger to input B instead.
knbPixels
#3 Posted : Tuesday, March 4, 2025 10:38:39 PM(UTC)
knbPixels
Ok thanks...Anyway, if anyone knows how to get around this issue let me know
dmwkr
#4 Posted : Wednesday, March 5, 2025 12:13:33 AM(UTC)
dmwkr
Don't know what you are trying to accomplish, but layers can also be used on input A itself (including a virtual input of A), and (de)activated as needed.
knbPixels
#5 Posted : Wednesday, March 5, 2025 12:21:19 AM(UTC)
knbPixels
Ok so here's an example.
There's a camera input, a layout that uses that camera input on a layer, and a third input where I want to load various titles on the layers (not speaker titles, just text title inputs). We will call that third input "Text Input".
What I want to happen, is when the camera input is used on the layout input and then brought on screen, I want that to trigger the SetLayer function on the Text Input, so that the layers I specify get loaded with the text I specify.
However, since the camera input is a layer on the layout input, the trigger that I put on the camera input never fires, even when the layout using it goes to program.
What's interesting to me is that despite this somewhat expected but unfortunate behavior, automixing still works. When you put the layout to program that has the camera on it as a layer, the camera's audio will unmute if you've turned on automixing. So in that case vMix DOES see the camera go to program, but it doesn't see it when it comes to triggers.
nikosman88
#6 Posted : Wednesday, March 5, 2025 2:01:14 AM(UTC)
nikosman88
Greece
Hi. Maybe a companion trigger can do what you need. Make a trigger like "on condition becoming true"-->internal-->check variable and as variable use the layer name for example "$(vmix:input_cameras_layer_1_name)" operation= "your camera name" and when this true-->do the action
knbPixels
#7 Posted : Wednesday, March 5, 2025 2:08:04 AM(UTC)
knbPixels
So that would work regardless of if the input containing the layer is on air or not. So it doesn't really replicate the functionality of watching the program state and performing an action when an input is on a layer taken to program.
nikosman88
#8 Posted : Wednesday, March 5, 2025 3:08:02 AM(UTC)
nikosman88
Greece
Yes and you can do combinations like this when happen and/or your layout is on air to do the action
knbPixels
#9 Posted : Wednesday, March 5, 2025 2:14:38 PM(UTC)
knbPixels
I appreciate your trying to help, but trust me. My show is extremely complicated and just watching to see if an input is on a layer is nowhere near as simple as watching to see if an input is on a layer on program. I'm not going to go into all the ways that this feature would help me but it would be massive.
mavik
#10 Posted : Thursday, March 6, 2025 12:58:43 AM(UTC)
mavik
last resort is to get into scripting. There you can do conditional actions.
nikosman88
#11 Posted : Thursday, March 6, 2025 5:23:30 AM(UTC)
nikosman88
Greece
Personally i think for actions like described the companion triggers and variables are more flexible
Roy Sinclair
#12 Posted : Thursday, March 6, 2025 9:05:23 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Use a MIX input. You can create triggers that are applied when an input is used in a MIX. So if your multilayer page uses a mix as an input you can set up the trigger so it is run when that input is made LIVE in that mix.
knbPixels
#13 Posted : Thursday, March 6, 2025 9:06:33 AM(UTC)
knbPixels
Tried that, triggers still didn't fire.
nikosman88
#14 Posted : Thursday, March 6, 2025 11:46:17 AM(UTC)
nikosman88
Greece
If i understand well what you need,still believe that companion is very easy to do. A trigger like this LAYOUT.png (2,459kb) downloaded 1 time(s). will do the trick. Or scripting in same logic
You dont need to watch if the specific input is on the layer,because that why it is called trigger. Companion will watch it (in a way pretty much like vmix watches the internal triggers) and if condition matches it will do the action
As for the feature request. Personally i also need some things for my workflow but until then,im trying to do workarounds
