On all 3 of my photo sequence stingers cut out without playing the latter transition and instead just cuts after the fullscreen portion. I have tried using the straight MOV file and there is the same problem. Changing cut timing doesn't do anything and have completely replaced the stinger with no change. The weird part is that the stinger will play correctly the first time, but then not again after that. I have seen other people have this problem but haven't found a good solution.
Joined: 11/14/2012(UTC) Posts: 395  Location: Finland Thanks: 250 times Was thanked: 36 time(s) in 34 post(s)
Originally Posted by: gRokz  On all 3 of my photo sequence stingers cut out without playing the latter transition and instead just cuts after the fullscreen portion. I have tried using the straight MOV file and there is the same problem. Changing cut timing doesn't do anything and have completely replaced the stinger with no change. The weird part is that the stinger will play correctly the first time, but then not again after that. I have seen other people have this problem but haven't found a good solution. vMix version? OS version?
