nicksimoneau
#1 Posted : Friday, February 28, 2025 1:25:11 AM(UTC)
nicksimoneau
Canada
Hi everyone, newbee question here, How can I record my audio bus as L/R stereo track?
Currently my L/R channel are mixed together. So I have for example input 1-2 in the bus A but the wav give me the same audio on the Right and Left channel.
I have a Soundcraft console and I want to have all my INPUT (12) recorded seperately.
Thank you :)
dmwkr
#2 Posted : Friday, February 28, 2025 1:44:05 AM(UTC)
dmwkr
Use the Channel Matrix in the Audio Settings of your inputs to assign them to indivdual busses:
https://www.vmix.com/help28/AudioSettings.html
Use the MABCDEFG channels option in Recording:
https://www.vmix.com/hel...OutputAudioChannels.html
nicksimoneau
#3 Posted : Friday, February 28, 2025 5:47:07 AM(UTC)
nicksimoneau
Canada
I have done that but the problem is the master become stereo but I need to get it mono.
I have try to add Audio Input and select vMix 16 channel but look at the result, even if I have check the Bus D, I cant get sound except if the master is checked too:
dmwkr
#4 Posted : Friday, February 28, 2025 9:39:51 PM(UTC)
dmwkr
Your screenshot shows audio settings of input 8. This input is muted, you have to unmute it. And, you still have to activate the busses in the Audio Mixer, not only in the Channel Matrix. Input 8 has no activated busses.
And, I just noticed you were talking about Multicorder. The recording of the channels can only be selected on the "normal" recordings.
WaltG12
#5 Posted : Saturday, March 8, 2025 3:25:27 PM(UTC)
WaltG12
It's a visual bug (although it's not even a bug, as it's a side effect of how it's designed).
You should have sound whether Master is enabled or not.
You just won't have meters on the input.
You should still have bus meters & they should still be active (as should, again, the sound).
See here:
Guest (7)
