Starr
#1 Posted : Thursday, February 27, 2025 2:00:01 AM(UTC)
Starr
Estonia
Hello!
After vMix startup, if I try to add input, it starts thinking for minutes, after this menu pops up, the same with Settings. Something is not right.
I have updated bios, graphics drivers, uninstalled vMix, installed vMix again, nothing changed.
Tried to optimize laptop settings for vMix, but still nothing.
I have no more ideas to solute this problem.
Can someone help me? Maybe over Teamviewer or Anydesk can come and find the problem?
Using vmix HD license.
Best wishes,
Ringo
mavik
#2 Posted : Thursday, February 27, 2025 2:11:32 AM(UTC)
mavik
Have you installed Lenovo Vantage and check the system. Settings and such take a bit on my side as well. No big deal tbh.
Starr
#3 Posted : Thursday, February 27, 2025 2:22:39 AM(UTC)
Starr
Estonia
I uninstalled it after I found the problem and started to update drivers and so on.
mavik
#4 Posted : Thursday, February 27, 2025 2:37:40 AM(UTC)
mavik
Please share what the root issue was so other can benefit for this. Thanks
Starr
#5 Posted : Thursday, February 27, 2025 5:31:49 AM(UTC)
Starr
Estonia
vMix starts up normal time. After it opens, everything looks normal. Laptopo CPU<1%, MEM 300Mb on vMix process, laptop total CPU 5%, MEM 40%, Disk 2%.
If I push "Add Input", the program starts thinking, and it takes 10 minutes to open Input window, then I can add input like laptop mic. Input comes active everything looks fine. So I opened vmix "Settings", it opened normal time. Then I tried again open "Add Input" and the program does nothing. ALT+TAB don't even bring the program on the top switching between different windows.
It looks like I have somekind of configuration conflict.
Starr
#6 Posted : Friday, February 28, 2025 12:47:46 AM(UTC)
Starr
Estonia
Found on the log file:
28.0.0.38 - NVIDIA - 27.02.2025 15:40:43
Error disabling ShadowPlay: vMix.GFXEException: Could not find NvNode
at hz.c(Boolean a)
at rzzzzzc.w()
28.0.0.38 - Performance - 27.02.2025 15:40:43
Windows 11 High Performance Timers Enabled: 2308
Installed vMix 27 and the error in log file is the same:
27.0.0.90 - NVIDIA - 27.02.2025 16:41:35
at hs.c(Boolean a)
at qzzzzzo.w()
Starr
#7 Posted : Friday, February 28, 2025 1:45:40 AM(UTC)
Starr
Estonia
Solution:
Nvidia Broadcast uninstall.
Probably it uses ShadowPlay, that vMix was not able to disable - it was the case.
