Ask about how to import Txt files
Joined: 2/19/2025(UTC) Posts: 9  Location: Ha Noi Thanks: 6 times
Hi everybody . I have something to ask about how to import a list of files in txt format to play the program. This txt file is exported by another software, and I want Vmix to receive this txt file and then export it to Vmix to run. Naturally, the drive containing the file to play from another machine and the Vmix machine have the same address (Storage). The only difference is that one machine exports a txt file to create a list and the Vmix machine just imports that txt to play. So what should I do? hope everyone can help me. Thank you
Originally Posted by: jaychip1001  Hi everybody . I have something to ask about how to import a list of files in txt format to play the program. This txt file is exported by another software, and I want Vmix to receive this txt file and then export it to Vmix to run. Naturally, the drive containing the file to play from another machine and the Vmix machine have the same address (Storage). The only difference is that one machine exports a txt file to create a list and the Vmix machine just imports that txt to play. So what should I do? hope everyone can help me. Thank you Talking less in riddles would help I asume the txt file contains location links to the video files? would help if more details where available about this file. There are probably more ways to get a solution (datasources, listinputs, scripts etc ) all depending on the exact goal and the source Also please have a look at the vMix youtube channel, there are tons of tutorial videos which will explain what all is capable within vMix , that knowledge might give you an answer to this and other questions
Originally Posted by: doggy  Originally Posted by: jaychip1001  Hi everybody . I have something to ask about how to import a list of files in txt format to play the program. This txt file is exported by another software, and I want Vmix to receive this txt file and then export it to Vmix to run. Naturally, the drive containing the file to play from another machine and the Vmix machine have the same address (Storage). The only difference is that one machine exports a txt file to create a list and the Vmix machine just imports that txt to play. So what should I do? hope everyone can help me. Thank you Talking less in riddles would help I asume the txt file contains location links to the video files? would help if more details where available about this file. There are probably more ways to get a solution (datasources, listinputs, scripts etc ) all depending on the exact goal and the source Also please have a look at the vMix youtube channel, there are tons of tutorial videos which will explain what all is capable within vMix , that knowledge might give you an answer to this and other questions Ok. Thanks Doggy :)
