ddrdave
#1 Posted : 3 months ago
ddrdave
I'm using Central Control CORE 1.1.0.42 on a 2024 Macbook Pro running macOS 15.3. CC is controlling functions (through a Behringer Xtouch Compact) on 4 separate VM instances running vMix 28.0.0.36. (EDIT: These VMs are property of the company I work for and I am probably not at liberty to update vMix currently.)
CC is consistently not remembering the vMix inputs I have mapped to a few faders/buttons. It's the same 2-3 input mappings every time too; they keep defaulting to just the first input I have in vMix (a media list). I have changed them back several times and then re-saving/re-loading the CC profile, which didn't fix the issue.
I've previously used Central Control 2.5 on a separate Windows laptop for this function and never had this issue. That would have been with an older version of vMix as well, probably 27.0.0.X but it may have been 26.0.0.X.
Any ideas? Is this just a Central Control CORE issue and if so, anything I should be doing differently?
