Joined: 12/22/2024(UTC) Posts: 14  Location: Collierville, TN
Im using vmix on win 10 with 24 inch monitor. My problem is that the input thumbnails are too big. I can see only one line of them and about 10 % of the next line. If i create a new input it puts it at the bottom. If i want to move it to the top, i have to take the mouse and move it up on level, then i have to scroll, then move it up another level, then scroll and move it up again. etc. I have tried different resolutions on the monitor but nothing seems to help. Is there a way to resize the input thumbnail? This is a major problem for me. thanks , Tom
Joined: 10/24/2023(UTC) Posts: 25   Location: Südtirol Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
There is a setting that allows adjustment in certain size increments. Under: Settings/Display/Input Size:  2025-02-21 07 26 52.png (25kb) downloaded 1 time(s).
Thank you. I learned something new. But i was already on the smallest size. But I did find that i can grab the top of the row with the mouse and slide it up which created 1-2 additional rows that i can see. The only draw back to this is that it makes the preview and the output picture much smaller. There still appears to be lots of room in the preview and output box but the pic is smaller. I can make do with this. At least now i can see multiple rows of the inputs. thanks so much. Tom
