Sorry for my stupid question, i'm new on this. I have a Title, how to automatically fade away the title without press 1 button. Thanks !  Screenshot 2025-02-20 alle 00.36.34.png (38kb) downloaded 3 time(s).
Thanks !
Based on what ?
thanks for your question,
i have uploaded a title in vmix, with InTransition FADE and OutTransition FADE i show it pushing play button "1" i need to clear the screen after x seconds, but OutTransition runs only deselecting "1" botton
hope to be clear
hope to be clear not realy but there are meny posts in this forum that might be related to your problem and many tutorial videos on how to use shortcuts, triggers and design titles
@ GCORTI You can set the "Duration" an Overlay channel stays on screen in the Overlay Settings (button at lower right), so if you only want it for 5 seconds, set the "Duration" to 5000ms. This video explains more about how to use and set-up Overlay channels in vMix: Ice
Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
or you simply use a trigger on the specific input if you have overlays with different lenghts of on screen time...
Love u all, resolved with overlay's timing.
Thanks.
GC
Joined: 11/27/2023(UTC) Posts: 137  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
you do not have to push the overlay to remove it ....in the bottom right, select "overlays", and according to the overlay channel number, set the duration,(9 secs. is the maximum (9000) the effect in, the effect out, save and test...if too long, make any adjustments..... I was using this method for as long as I can remember.
