GT
Visibilty Problem
Joined: 7/15/2021(UTC) Posts: 14   Location: Baghdad Thanks: 7 times
Hi I faced a problem and haven't found any solution yet. I can't set visibility with a key for a rectangle although there is a visibility toggle in Title Editor as attachment. Doing this for text and image is easy but I can't find any solution for it.Because I can't use this element as image because of its variable colors. Who can help me to solve this problem thanks in advance.  Fill.jpg (69kb) downloaded 10 time(s).
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
You could use 8-digit hex code for color, with the last two digits representing alpha channel (00).
 1 user thanked dmwkr for this useful post.
Originally Posted by: dmwkr  You could use 8-digit hex code for color, with the last two digits representing alpha channel (00). you mean instead of SetVisibility use SetColor? what to do with QRCode?
Originally Posted by: Ham4u62  Originally Posted by: dmwkr  You could use 8-digit hex code for color, with the last two digits representing alpha channel (00). you mean instead of SetVisibility use SetColor? what to do with QRCode? Use pages within the title, and use fade animation of the item in question.(ex. page1 visible, page2 hidden) for shortcuts use TitleBeginAnimation with the Pagex as value to select the specific page
GT
Visibilty Problem
