Analogsound
#1 Posted : Friday, February 14, 2025 12:22:47 AM(UTC)
Analogsound
Hello all. I've been using Vmix for almost 4 years now. Over the past 3 months I've been getting random FFMPEG errors when recording a file. The log file doesn't tell me much. Has anyone else run into this issue? The weird part is the record will stop after a couple seconds, I'll restart the record and it will record just fine. It's almost like a Hiccup in the software or my system. I've made virtually no changes to my set up over the past few years I've been using Vmix. Just basic windows updates. I'll insert a screen grab of the error. Random FFmpg error.jpg (537kb) downloaded 2 time(s).https://forums.vmix.com/resource.ashx?i=5586&b=1&editor=true
WaltG12
#2 Posted : Friday, February 14, 2025 1:32:50 AM(UTC)
WaltG12
While it may not be much, it might help if you shared what it actually told you.
Additionally, have you tried sending an error report and contacting Support?
