MRedZac
#1 Posted : Monday, February 10, 2025 4:52:07 PM(UTC)
MRedZac
Germany
Hello !
Anyone else facing issues after the Microsoft 24H2 and 2025-01 Updates ? - vMix came up with a Message, that the hardware has been modified and that it needs a reactivation of vMix. Just imagine !
Had similar problem with my waves plugins as well, as after installing the updates in Windows, something changed in the way the hardware is recognized and that deactivated all of waves plugins. Funfact: These plugins can only be recovered once a year, so I am forced to turn of all Windows Updates to minimize the risk, that after the next updates, the same or similar issue will come up again...
I am working as IT support and also at my workplace, we had hundreds of computers, where 24H2 was not installing properly and had to be forced to install by a repair installation from the Windows Image... Sorry Guys, but Microsoft is more and more bullshitting and this is not acceptable ! High time for vMix to change OS plattform...
Cheers
Marco
thanks 1 user thanked MRedZac for this useful post.
jet on 2/10/2025(UTC)
jet
#2 Posted : Monday, February 10, 2025 6:35:23 PM(UTC)
jet
Was thanked: 23 time(s) in 21 post(s)
+1
WaltG12
#3 Posted : Tuesday, February 11, 2025 1:03:00 PM(UTC)
WaltG12
Look up what the registration is tied to.
Now you know how to overcome that issue moving forward, if this happens again.
To what?
Because if you want to talk about Waves plugins, Mac users have far more issues with needing to buy the upgrade plan to make their plugins work again than Windows users do.
Mac updates, even outside the very plugins that you yourself mentioned which have a reputation for breaking with Mac updates, are far more likely to break software than Windows updates are.
So that's certainly not the answer to that problem.
And switching to Linux or any Linux offshoots are just going to cost them marketshare, because people will just move to a competitor before they move their entire OS to Linux to keep using vMix.
So what's that leave?
MRedZac
#4 Posted : Tuesday, February 11, 2025 9:53:30 PM(UTC)
MRedZac
Germany
To what?
Concerning Waves registration: It was tied to the internal network card and after the update it was tied to wifi card instead and it was not possible to revert it back to the internal lan card...
Concerning OS: You are obviously not informed yet, that Microsoft is about to move Windows completely into the cloud. There will be no "offline" Windows on computers anymore the way we know it now, soon. Anyway, Microsoft is constantly losing market shares. They came from over 95% and now they barely have 65-70% left... If they go on following their plans to move Windows completely into the cloud, their shares will even drop faster...
I am also not talking about to stop development for Windows, but at least it would make sense to start linux developement in parallel to be prepared for day X to come... And this day WILL come, that's a matter of fact or what you think all this Windows 365 topic is about...!?
nikosman88
#5 Posted : Wednesday, February 12, 2025 9:47:03 AM(UTC)
nikosman88
Greece
Windows 10 until the sun rises in the west! Practically, no one is forcing us to upgrade to Windows 11. My only personal hope is that vMix doesn't "abandon" us and make future versions exclusively for Windows 11 and beyond. If, in the future, Windows 13-14 improve (after all, Microsoft is known for failures like Vista, etc.), then yes, we can move forward.
DMack
#6 Posted : Wednesday, February 12, 2025 11:34:57 AM(UTC)
DMack
We have Windows Updates disabled on all of our vMix servers and I would never allow Windows to do any auto updates on any of our production machines. When we do decide to updates, they are tested on one of our dev boxes, evaluated carefully to see if there is any impact on vMix and several other apps and then and only then do we manually update our servers.
Never had an issue..
stevethornley
#7 Posted : Tuesday, February 18, 2025 9:11:24 PM(UTC)
stevethornley
Bumping this thread as linked to our experience. Cannot believe we are the only ones.
https://forums.vmix.com/...1-24H2-update#post117681
DMack, you say:
I do try to turn-off windows update in services.msc but Microsoft still manage to get their nags through to update. In our case, an unsuspecting user went forwards with the update and now we are left with a machine that cannot access the audio inputs! Unfortunately, this device is being used for streaming daily and so we are waiting for a weekend to either roll-back, re-install vMix or use the back-up machine (which is running Windows 10, ironically). Wanted to gauge the Community's views before deciding which order to tackle things in! :)
Thanks to all.
nikosman88
#8 Posted : Wednesday, February 19, 2025 1:41:58 AM(UTC)
nikosman88
Greece
DMack, you say:
Thanks to all.
The problem is that you use old vmix version. 24 is 4 versions back and latest 28 version is 10 times better.Vmix 27 and 28 work ok at windows 11 24H2. If you do daily streaming the 60$ that need to update are a fair amount of money and worth it
Although i avoid personally windows 11 not because only vmix but in generally because i like the "if work dont change it" but i know if my pc breaks i will need new pc with windows 11 or used HW.
MickeyMJJ
#9 Posted : Wednesday, February 19, 2025 2:43:21 AM(UTC)
MickeyMJJ
Was thanked: 9 time(s) in 8 post(s)
DMack, you say:
Thanks to all.
Indeed, even if users have had problems with this update, you might want to update your version of vMix instead of blaming Windows 11 directly...
WaltG12
#10 Posted : Monday, March 10, 2025 11:50:29 AM(UTC)
WaltG12
Since you need this spelled out: it's not tied to the card.
It's tied to a particular identifier that the card uses.
That identifier is not immutable. There are a million guides on Google with step by step info on how to change it with various software tools, including system tools built into Windows.
If you happen to use those software tools to swap the identifiers of the 2 cards & give the licensing software the GUID it's looking for on the card where it's looking for it, it'll find exactly what it expects to find and you won't have to reconfigure the licensing.
Roy Sinclair
#11 Posted : Tuesday, March 11, 2025 7:59:17 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
DMack, you say:
Thanks to all.
Use the rollback option to remove those updates. 24H2 decided my product key was bad when it installed on my home PC despite the fact that it was the ONE copy of Windows that I paid full price for though I did buy it through Amazon (Amazon itself, not a reseller on Amazon). I rolled it back and everything was fine again until it decided to install 24H2 again and I had to roll it back again and this time disabled all updates until MS can tell me why they broke it.
EDIT: Also please note that MS has a version of Windows they sell for use in standalone environments like ATM machines that have 10 year guaranteed support and all the nonsense found in their normal consumer and business versions stripped out. Support of the last Windows 10 released version of that will run until 2031. Likely you will replace your PC vMix is running on before that version of Windows 10 is no longer supported.
