Feature Requests
Error when starting stream
Joined: 6/30/2022(UTC) Posts: 1  Location: Wellington
Any idea what it means? If I close message I can connect generally on the second attempt, that tells me the key etc is correct. I have space on servers, I have internet bandwidth 500 mbits+, Vmix Program is 27.0.0.91, PC is same one used fine for couple of years, nothing changed IBM support says it's Vmix software
Error Message
FFMPEG1.Exited Streaming [rtmp @ 05e95980] Cannot open connection tcp://23123891.fme.ustream.tv:1935 rtmp://23123891.fme.ustream.tv/ustreamVideo/23123891/.....: I/O error
libavcodec 57.106.101 / 57.106.101 libavformat 57. 82.101 / 57. 82.101 libavdevice 57. 8.101 / 57. 8.101 libavfilter 6.105.100 / 6.105.100 libswscale 4. 7.103 / 4. 7.103 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio': Duration: N/A, start: 79763.966000, bitrate: 1536 kb/s Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1920x1080, 50 fps, 50 tbr, 10000k tbn, 10000k tbc Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s [dshow @ 02b17bc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (63% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02b17bc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (65% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02b17bc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (68% of size: 128000000 [rtbufsize parameter])! frame dropped! [dshow @ 02b17bc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (70% of size: 128000000 [rtbufsize parameter])! frame dropped! [tcp @ 05e95e00] Failed to resolve hostname 23123891.fme.ustream.tv: Temporary failure in name resolution [rtmp @ 05e95980] Cannot open connection tcp://23123891.fme.ustream.tv:1935 rtmp://23123891.fme.ustream.tv/ustreamVideo/23123891/: I/O error [dshow @ 02b17bc0] real-time buffer [vMix Video YV12] [video input] too full or near too full (72% of size: 128000000 [rtbufsize parameter])! frame dropped!
Any idea what it means, if I close message I can connect generally on the second attempt
Feature Requests
