Feature Requests
Option To Create Shortcut Key To Enable/Disable Web Controller
Would it be possible on a future update of vMix to add a hotkey shortcut option to enable/disable Web Controller without having to go to the Settings menu?
When we do our sports broadcasts, our replay operator's computer uses the web controller to send commands to the production computer. We are in separate studios each running vMix. He handles replay while I produce and sends me the replays to me via SRT feed. When he sends a replay, I have a script set to tell my system to play a specific stinger and go to the input with his feed, then another script returns my program output to a live video feed. It all works really well.
The problem is when going to a break, if we go to commercial before the replay ends, his command still overrides the break and screws it up. If I had a shortcut key to toggle the controller on and off, that would fix the problem.
Feature Requests
