Map Datasource to Title using Script
Joined: 2/4/2025(UTC) Posts: 6  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hey everyone,
I have some big titles in my production with a lot of fields to be populated. The datasource to be used is a google sheet. I used to manually assign the title's fields to the corresponding cells of the sheet. That works perfectly, however it takes a lot of time to assign the fields by hand and it is very error prone. I would like to assign the cells of the datasource via a VB.NET script. I thought this would be a very easy task to do with a script but didn't find a way to do it. Basically I want to set row and column inside of the sheet for every field in my title. I don't want to read out the sheets data and set the title's text, I only want to assign the corresponding rows and columns.
Any help would be appreciated, thanks in advance :)
Best regards Felix
Best regards Felix The very old "trick" is to name the column headers the same as the title text fields (according the vMix User Gude ;-) ) and use the "Auto" option
Thanks for the reply, I will try that. But what about the rows? Do I still have to assign them manually or is there also some "auto" way of doing this? My problem is the data is scattered around the sheet but I try to bring it to standard table form.
Originally Posted by: FelixS  Thanks for the reply, I will try that. But what about the rows? Do I still have to assign them manually or is there also some "auto" way of doing this? Whenever you select a row *within the datasource or using shortcut functions) all its data that is linked to a title (column) will show their content from that row have you watched the mutliplt vMix tutorial videos regarding titles and datources ? Quote:My problem is the data is scattered around the sheet but I try to bring it to standard table form. seems a reorganisatoion of the datatable is in order. If there is some logic to the scatter a script could convert it into a more suitable table
Quote:seems a reorganisatoion of the datatable is in order. I added a bunch of new pages to my google sheet with only one row and a lot of labeled columns. Looks stupid but works like a charm! However, some columns with static values are also being auto-assigned despite of the fact that I don't want them to change while having a completely different name than the field inside of the title. Seems totally arbitrary to me but it took only a few minutes to manually correct these instances. Made me go down from over an hour of concentrated work to less than 10min. Thank you!
 1 user thanked FelixS for this useful post.
