Instant Replay
Instant Replay to Mix 2 with Stinger
Joined: 2/4/2025(UTC) Posts: 6  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hey everyone,
I am broadcasting a handball tournament and have a LED-Wall inside the Venue for the local viewers. Main Output ist going to the stream, Mix 2 is going to the LED-Wall. I want all my Instant Replays play out to the stream (obviously easy) AND to the LED-Wall at the same time. Basically a way to send the Replay to both. I tried showing the Replay input itself but I can't use my stinger this way.
Thank you for your help :)
Best regards Felix
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Temporarily switch your Fullscreen or External Output for the LED to "Output" instead of the mix input, for example with an OnOverlayIn trigger on your stinger input. In vMix 28 it is also possible to send overlays/stingers to mix inputs.
 1 user thanked dmwkr for this useful post.
Thank you, I will try that. I've seen the new vMix28 features but I will be still working with 27 for some time.
Originally Posted by: dmwkr  Temporarily switch your Fullscreen or External Output for the LED to "Output" instead of the mix input, for example with an OnOverlayIn trigger on your stinger input. In vMix 28 it is also possible to send overlays/stingers to mix inputs. In case anyone has the same problem, here is how I did it. I managed to get it to work in vMix28 with an OnOverlayIn trigger on my stinger and using the new stinger transition with my mix 2. However I needed to use a second identical stinger for this, otherwise it will trigger itself and stops working. Only issue I have, is the fact that mix 2 has to have the replay channel in preview for it to work. I am trying to get rid of that too, so that I don't have to worry, what is in it's preview.
Instant Replay
