klegault
#1 Posted : Saturday, February 1, 2025 1:30:10 AM(UTC)
klegault
Canada
Im trying to have to seperated feeds that act as program. I know i can duplicate program output to an external output however thats not what i need. I have online participants within a zoom call and im isolating their image. I also have in room participants which are captured from a robotic cam and fed back to vmix to zoom. Currently im using my program output to send out for zoom. This means i can never use that output on my monitors in room. Which means i have no way of using my lowerthirds (overlay) on an external output. Im at a point where im thinking of using two seperate vmix machines just to achieve two outputs with different feeds and different lowerthirds.
Using vMix v27.0.0.89
Blackmagic Desklink studio & Decklink 4k for routing I/O
dmwkr
#2 Posted : Saturday, February 1, 2025 2:20:26 AM(UTC)
dmwkr
A) You can activate/deactivate overlay channels on the outputs, also in vMix 27.
https://www.vmix.com/help27/SettingsOutputs.html
B) If that alone is not enough, because you need a completely different feed: In vMix 28 you can send overlays to mix inputs (and route the mix input to your output).
https://www.vmix.com/help28/Mix.html
thanks 1 user thanked dmwkr for this useful post.
klegault on 2/1/2025(UTC)
nikosman88
#3 Posted : Saturday, February 1, 2025 6:32:40 AM(UTC)
nikosman88
Greece
For A The problem is that if in output 2-4 until vmix 27 we have anything else other than output,overlay channels dont work. But in Vmix 28 we can send any input to a mix input-->overlay this and then output.
klegault
#4 Posted : Saturday, February 1, 2025 6:55:39 AM(UTC)
klegault
Canada
I knew of option A and could never get any overlays to show up properly on any output other than program but i think option B is exactly what i need. I did not know of the mix input option. Many thanks to your quick response.
