spinfold
#1 Posted : Wednesday, January 29, 2025 5:03:41 AM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
Just installed and have been playing with v28, released today. So far loving that our master production is much simplified with the flatten layers option - I've saved 5 mix inputs!
I was playing with the new Multiview as well, and wondered if it would be relatively simple to include Outputs as selections? Currently I have no way to monitor an ACTUAL output, video and audio, as it leaves vMix.
As an extension, it would also be awesome to be able to monitor vMixCall sends (up to 8 of them) and the send going to Zoom too - again, audio and video. Currently there is no way to monitor this.
Easy? Could it make its way into a v28 version? Pretty please?
nikosman88
#2 Posted : Wednesday, January 29, 2025 8:30:36 AM(UTC)
nikosman88
Greece
+1
"Currently there is no way to monitor this"--?>We have 4 outputs and hope at Vmix 29 give us 5. Beyond this,is doable. Maybe complex or not,but doable
So for now if we ndi out these outputs,then ndi in them if you really want to monitor them from out and make some script code or companion triggers that will appear a title in the specific ndi input like "output 3 sends to ... call "name"" because in the api xml for vmix calls exist which output it has.
Also now within Vmix 28 in the API we have the outputs info for the inputs,so in Multiview we can have the inputs that we send in Outputs and up to them a small title/sign like "this is your output2,3,4" that will be informed in realtime if this changes
So there exist ways to monitor the outputs
spinfold
#3 Posted : Thursday, January 30, 2025 6:37:36 AM(UTC)
spinfold
+1
Appreciate for Outputs 2, 3 and 4 I can NDI out and then bring them back in as inputs, but that takes up network bandwidth, inputs and GPU, which is unnecessary as vMix is already generating these feeds, there is just no way to monitor them as they leave.
For the sends to vMixCall inputs and Zoom, these are not even available on NDI so I can't use this workaround.
The use case I see this for is being able to see, in particular, the correct audio is reaching the right places. For example when one vMixCaller is speaking on air, I would love to see that there is no audio going to that person's send because of the auto mixminus. And, if I change the audio bus being sent to an output to, say, tone then I would love to be able to see this in a Multiview.
