4advancedproductions
#1 Posted : Saturday, January 18, 2025 5:26:51 AM(UTC)
I cannot find anywhere that says if vMix is Windows 11 compatible. I want to upgrade before Windows 10 loses support but I do not want to lose vMix.
#2 Posted : Saturday, January 18, 2025 5:54:32 AM(UTC)
You won't "LOOSE" vMix :-)
So far the only issue i have had with it is I am supposed to buy new serial to USB cables as W11 driver keeps saying my current ones are not compatible (chip) but heck using an older driver (and blocking it being updated) makes them work just fine :-)
4advancedproductions on 1/18/2025(UTC)
#3 Posted : Saturday, January 18, 2025 5:57:39 AM(UTC)
Haha thanks for the grammar correction :P
What is a serial to USB cable used for? The only cables I use currently are HDMI and ethernet. Will those be affected?
#4 Posted : Saturday, January 18, 2025 6:10:06 AM(UTC)
a) that was by accident ;-)
b) Interfacing with electronic timers (scoreboards) and vMix (has to do with the chip used within these "converters" )
c) not aware of them having to be different
