2 Pages<12
cwilms
#21 Posted : Wednesday, January 15, 2025 8:11:18 AM(UTC)
cwilms
Canada
Originally Posted by: thecloudmediagroup Go to Quoted Post
We get about 175 milliseconds or so of latency which is acceptable to me. The people in the audio booth that get a live audio signal and the slightly delayed video feed do not notice a sync issue with speech and video. Acceptable is a subjective term.
If you go with vMix for the IMAG solution I would definitely use the Magewell capture cards and output your signal in 60p. The faster frame rate cuts down your latency because vMix is able to send out a frame after a 60th of a second instead of a 30th of a second. Also send the native resolution to your screen to cut down any latency with scaling.
We have been doing IMAG with vMix in our church for probably 4 years. The video below is an older video with a hair more latency than we have now.
Are you still using vMix for IMAG? Is your latency still the same or has it improved? What hardware do you run vMix on?
robertskiba
#22 Posted : Wednesday, January 15, 2025 10:48:49 PM(UTC)
robertskiba
Germany
My experience is that the Atem is not the perfect device for this, but the latency is totally OK.
But you should use vMix only as a graphics processor and output the graphix over a transparent background with a blackmagic decklink duo or ultrastudio mini card as cut&fill output. This works quite good for lower thirds etc.
If you want to have a professional thing, use analog way equipment or barco.
nikosman88
#23 Posted : Thursday, January 16, 2025 12:33:17 AM(UTC)
nikosman88
Greece
For simple talk shows the workflow camera hdmi/sdi out-->decklink hdmi/sdi in-->vmix and the vmix-->fullscreen out-->gpu-->tv monitor in the talents room, the latency is acceptable. For more professional things,more professional and expensive equiqment is needed
2 Pages<12
