Vmix with Røde Rødecaster pro II
Hi All
I would like to use Røde Rødecaster pro II togetger with the my vmix setup for a video podcast studio.
The reason for this choice is that the Røde sound mixer makes really good sound together with the Shure mic. But my problem is that I can't figure out how to set it up properly so that I still have each audio channel in Vmix separately (there are 3 mic and 3 in ear sound returns). When I download the software from Røde it seems like I can only get a finished R/L output from the Røde sound mixer. This gives me a little problem when I have to do a mix minus for each of them in the studio. You can also do a mix minus on the Røde sound mixer itself, but then I miss everything else from Vmix. How do I do this in the best way?
Joined: 10/31/2020(UTC) Posts: 203  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
According to the manual, if you enable multitrack recording, then you get all the individual tracks as separate audio devices in your computer.
To activate multitrack recording via USB, go to settings then ‘Outputs’ > ‘Multitrack’ > ‘USB’ and deselect ‘Off’.
