Concurrent SwapLayerAnimated calls are disallowed
Joined: 2/23/2023(UTC) Posts: 94  Thanks: 30 times Was thanked: 20 time(s) in 6 post(s)
I attempted to simultaneously swap two layers using the SwapLayerAnimated function: Code:Function=SwapLayerAnimated&Input=0&Value=1,3,1000
Function=SwapLayerAnimated&Input=0&Value=2,4,1000
However, making the second SwapLayerAnimated call causes the first to immediately finish and skip to the end of its animation. I would have expected both to run to completion. vMix 28.0.0.27
Originally Posted by: ryxyz  I attempted to simultaneously swap two layers using the SwapLayerAnimated function: Code:Function=SwapLayerAnimated&Input=0&Value=1,3,1000
However, making the second SwapLayerAnimated call causes the first to immediately finish and skip to the end of its animation. I would have expected both to run to completion. vMix 28.0.0.27 Is the same behavior as like putting an animated title in overlay and instantly doing the same with another animated title on the same overlay before first animation is finished One has to let the first animation ( function ) finish before the next one is started . Has been like this forever within vMix = normal A (same) function can only be called one at a time , if the second one is called before the first one has finished processing (duration of animation for example) the second one (call) takes precedent ( better than ignoring the second one ;-) )
