CAn I trigger script from one vmix machine at other vmix machine after replay clip is over?
Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
Hi, is it somehow possible to trigger script at PC2 when replay clip at PC1 is over ? If so how :-)
Reg. Tommi
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: -TA_  Hi, is it somehow possible to trigger script at PC2 when replay clip at PC1 is over ? If so how :-)
Reg. Tommi NO not possible BUT... Martin just added a new trigger to the v28 preview today: OnReplayEventsCompleted so you could use that one to calla script (that sends a httprequest) to instruckt your other pc to do something (like calling a script there) old way would be to check with a script if the replay is in output or not
Originally Posted by: doggy  Originally Posted by: -TA_  Hi, is it somehow possible to trigger script at PC2 when replay clip at PC1 is over ? If so how :-)
Reg. Tommi NO not possible BUT... Martin just added a new trigger to the v28 preview today: OnReplayEventsCompleted so you could use that one to calla script (that sends a httprequest) to instruckt your other pc to do something (like calling a script there) old way would be to check with a script if the replay is in output or not And OnTransitionOut works also. Version 27
Originally Posted by: -TA_  And OnTransitionOut works also. Version 27
OK then, my mistake
