cant stream to facebook group
Joined: 12/22/2024(UTC) Posts: 14  Location: Collierville, TN
Is anyone else experiencing issues trying to stream to facebook groups using vmix 27? I am testing vmix and have found that i can set up stream using rmtp to x.com and also Twitch.tv(they work fine) but facebook fails and will not connect. I have been a user of Telestream Wirecast and it connects to facebook groups.
a while back facebook removed their api therefore now you have to manually use the rmtp. Also you have to go into facebook/live/create and set up the stream. But this works with wirecast, obs, etc. will not work with vMix.
anyone else have this issue and if so did/how did your resolve it? Thanks, Tom
Joined: 3/17/2017(UTC) Posts: 452  Location: Luzern - Schweiz Thanks: 69 times Was thanked: 57 time(s) in 51 post(s)
Thanks so much. using links above i have facebook group working.
