tsioukas
#1 Posted : Monday, April 29, 2024 5:36:19 AM(UTC)
tsioukas
Greece
I am wondering if vMix works at its designed on TCP/API
Based on example in documentation this command
Code:
FUNCTION PreviewInput Input=5\r\n
sould give the response
Code:
FUNCTION OK PreviewInput\r\n
Instead of that it gives this
Code:
FUNCTION OK Completed
The problem is that if we give a lot of commands we don't know when they executed and if executed normally, because it's imposible to monitor the responses.
For example I send the command
Code:
FUNCTION SnapshotInput Value=snapshot.png Input=1
it takes about 1-2sec to executed. If I get only the "OK Completed" response I don't know if the snapshot completed (to proceed to further actions on my code) or if the response was from another function that runs simultaneous.
Is this working as it designed?
By the way, is it possible to make it to return the image as Buffer instead saving the snapshot into a file.
Thank you
#2 Posted : Monday, April 29, 2024 6:48:07 PM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
Only one command should be run at a time.
The only exceptions to this are TALLY and ACTS responses which may be received at any time, but these have different responses to FUNCTION so shouldn't cause any conflicts.
The part of the response to look for is FUNCTION OK, the text after it is informational only, such as more information on the error in the case of FUNCTION ER
tsioukas on 4/29/2024(UTC)
tsioukas
#3 Posted : Monday, April 29, 2024 7:45:46 PM(UTC)
tsioukas
Greece
Thank's, the response "FUNCTION OK PreviewInput\r\n" as it written on your documentation confused me when I notice that. Acts return preview function in a different format "ACTS OK InputPreview 1 1".
In my code I detect last command (with a queue) to emit an event if a specific function executed and needs further actions. But I thought that a solution like "FUNCTION OK PreviewInput\r\n" etc. will make my code simpler.
Thank you again.
P.S. I know that is difficult, did you think if it’s possible to add a function that return snapshot as image buffer? I use sharp on nodejs to read local file and edit/crop this snapshot, and with this I will avoid the use of tmp file. [please... ;)]
tsioukas
#4 Posted : Thursday, May 2, 2024 7:10:49 PM(UTC)
tsioukas
Greece
I think, after all, to avoid any misunderstanding, Function description on documentation
Commands
FUNCTION
Format: FUNCTION <Function> [QueryString]\r\n
Example Request: FUNCTION PreviewInput Input=5\r\n
Example Request: FUNCTION SetText Input=3&SelectedName=Headline&Value=Hello world\r\n
Example Response: FUNCTION OK PreviewInput\r\n
Example Response: FUNCTION ER Error message\r\n
need to replace "Response: FUNCTION OK PreviewInput" with "Response: FUNCTION OK Completed" as it never gives this type of response.
Dist
#5 Posted : Friday, December 20, 2024 1:10:41 AM(UTC)
Dist
Was thanked: 27 time(s) in 19 post(s)
+1 to this
I was looking to implement better logging in an app, but unfortunately as previously stated the TCP response to successful functions is "FUNCTION OK Completed" which is not particularly helpful to differentiate what succeeded and what failed when there's no sort of incremental number ID, nonce, or the return of the function being requested which was completed.
While "Only one command should be run at a time." might be an excuse for why the current functionality may be sufficient for some use cases, it's not how all users use vMix and productions are performing increasingly complex setups and macros utilizing multiple functions being run concurrently or on quick succession. And even if it's not something that is planned to be implemented at the very least the documentation should be updated as even the most recent docs (and beta v28 docs) include "Example Response: FUNCTION OK PreviewInput\r\n" which indicates that the function requested is returned in the response which is incorrect.
thanks 1 user thanked Dist for this useful post.
tsioukas on 12/20/2024(UTC)
#6 Posted : Friday, December 20, 2024 2:59:16 AM(UTC)
As mentioned, do not send multiple requests without waiting for a response each time.
We can look at updating the documentation, however please note that any text after OK or ER is informational text only, and is subject to change as a result.
(For what it is worth, there is no benefit to trying to batch commands, as vMix processes all commands in a serialized manner, and will not proceed to the next command until
the response is sent anyway.)
