cdwinans
#1 Posted : Monday, December 16, 2024 1:24:30 AM(UTC)
cdwinans
So this is a little different. I have a volunteer camera operator at my church that has Asperger's and during the worship time, there is no way to keep him from shaking his legs and bouncing up and down. The camera station is on a wooden platform and we are struggling to get the picture to not shake. His camera winds up being unusable during the worship time.
Any affordable options that has worked for anyone else?
Thanks!
sinc747
#2 Posted : Friday, December 20, 2024 2:13:26 AM(UTC)
sinc747
I feel your pain. Volunteers can bring all sorts of challenges.
It sounds like you need a more stable platform. Is there a way to add cross bracing to the existing platform?
- Tom
dmwkr
#3 Posted : Friday, December 20, 2024 2:55:02 AM(UTC)
dmwkr
Maybe build a second platform/somehow split up the platform, so you have one for the operator and one for the camera.
#4 Posted : Saturday, December 21, 2024 11:09:40 PM(UTC)
@ cdwinans
I would explore cameras and/or lenses with internal stabilization options or an external gimbal/stabilizer system.
(Probably a lot cheaper than building a more stable platform)
cdwinans
#5 Posted : Friday, December 27, 2024 4:21:06 AM(UTC)
cdwinans
Our platforms are basically a 5' tall plywood box with a top about 4'x4'. There's barely enough room for what we have, so splitting it up would be difficult. They weigh a ton, so tipping them over to try to add support underneath the top won't be easy. I think my first step will be to get a rubber mat to put the tripod on, but I doubt that will have much impact. The kid bounces like he's at a concert. :(
As for cameras, they already have image stabilization built in. I guess what I am asking is if anyone has any experience with tripos mounts or gimbals that would help in this situation. Price will definitely be an issue. Our budget is very limited so I'm guessing I'm not going to find the unicorn I'm looking for, but thought I would ask.
Thanks!
elvis55
#6 Posted : Friday, December 27, 2024 4:52:03 AM(UTC)
elvis55
Switzerland
Mount the camera on the ceiling using a “camera ceiling mount”.
mntechnogeek
#7 Posted : Sunday, January 5, 2025 4:48:26 AM(UTC)
mntechnogeek
It's typically a bad idea to have the camera operator and the camera tripod on the same physical platform. There are things called SpiderPods that accomplish this in a pretty compact form-factor. The operator platform is small, but a barstool can be secured to it if needed.
Other options:
Take his chair way so he stands to minimize the shaking. I don't recall if you have him seated, but this an option (although a bit brutal for him, I'm sure.)
Get a very nice PTZ camera and make him the remote robo-op.
HTH
