Dam2media Solutions Int'l
#1 Posted : Wednesday, December 18, 2024 6:47:01 PM(UTC)
Nigeria
I was trying to add my external Audio USB Device from the Audio Input but is given me "Attempted To Read Or Write Protected Memory. This Is Often An Indication That Other Memory Is Corrupt" even when I switched over to Built in Audio my system mic is not working
nikosman88
#2 Posted : Wednesday, December 18, 2024 7:32:04 PM(UTC)
nikosman88
Greece
Hello. At first check your windows version if it is windows 11 24H2. If yes,then check Vmix version and if you have 26.0.0.45 or older,check vmix updates. You need to update at Vmix 26.0.0.46 or Vmix 27 or if you still are in Vmix 25 there also exist an update for it. There no exist other way to make vmix 26.0.0.45 and back to work in windows 11 24H2 version
